Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Is this normal? (https://honda-tech.com/forums/forced-induction-16/normal-888682/)
tolowhb Jun 7, 2004 04:07 PM
Is this normal?
Ok, I installed a greddy turbo kit on my d16z6 this was about two months ago. Well I just removed the the filter on the intake side of the turbo to check for oil or anything werid, and I cam accross a small amount of something that felt like oil but did not smell like oil at all. Could this just be something from breaking the turbo in? And could it be caused by the turbo seals breaking in seeing how my turbo was brand new? Thanks!
tolowhb Jun 7, 2004 04:22 PM
Re: Is this normal? (tolowhb)
Oh and the intake for the turbo has a hose ran to it from the valve cover, this would probably leave some oil near the turbo huh?
2000GSRT Jun 7, 2004 04:22 PM
What type of filter are you running? It could just be the oil they use on the air filter that has collected a lot of dirt and grime.
tolowhb Jun 7, 2004 04:28 PM
Re: Is this normal? (2000GSRT)
I am using the one that came with the greddy kit, looks like a cheap foam filter.
tolowhb Jun 7, 2004 04:46 PM
help
2000GSRT Jun 7, 2004 04:56 PM
did you find the oil in the piping or on the filter?
tolowhb Jun 7, 2004 05:03 PM
It was right after where the intake connects to the turbo. I have read some posts where people say it is normal. But I want other point of views.
tolowhb Jun 7, 2004 06:02 PM
Can anyone else ease my mind?
tolowhb Jun 8, 2004 03:15 AM
bump
White Smoke Jun 8, 2004 05:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb &raquo;</TD></TR><TR><TD CLASS="quote">I have read some posts where people say it is normal.</TD></TR></TABLE>
That is correct https://honda-tech.com/forums/images/smilies/emthup.gif If you have the port off the valve cover taped into the air inlet pipe than you proly just pulling oil vapors from the crankcase called blowbye. I highly recomend investing in an after market catch can system to elimate this.
How much U boostin? Could you post us a pic?
FredoSP Jun 8, 2004 05:57 AM
hows your compression doing?
