No air flow to radiator..... Need help!!!!!
Old 09-30-2015, 11:46 AM
  #126
Quick search http://www.hondata.com/forum/viewtopic.php?t=16698
Looks like the fan switch controls the fan still even with the override fan control checked
You can make the fan turn on earlier with that function and control the shutoff speed that is all.
So the fan oscillating will depend on your fan switch. The temp can vary depending on age of that sensor
turbohatch96y7 is offline
Old 09-30-2015, 01:00 PM
  #127
Who is Mr Robot?
wantboost's Avatar
Default Re: No air flow to radiator..... Need help!!!!!
Or eliminate the fan switch and give the ecu total control.
wantboost is offline
Old 09-30-2015, 04:01 PM
  #128
bigodub93's Avatar
Originally Posted by turbohatch96y7 View Post
So did the fan cycle on and off at idle? Your target temp is 199 so the fan should turn on at that temp then turn off below that. Unless thats not how hondata works. I havent used it in a while.
Aem has 2 target points for temp.
On above 188
Off below 178
Also i would lower the rev limit on the over heat protection
Something like 5k
I don't even know how that parameter works. I just clicked it and did what you told me. Lol. The fan does not turn off at all at idle. This has to be because the temp is still to high. When I hot home from work I cut the engine off left the key turned so the fan was on and eventually the fan cut off by it self. So it does function correctly I just need to raise the temp that the fan cuts off at if I want it to cycle at idle. Now I have to figure out how to do that
bigodub93 is offline
Old 09-30-2015, 07:45 PM
  #129
Old 09-30-2015, 07:49 PM
  #130
These Are the temps i see and i have he same fan as you and a shitty fluidyne radiator.
You can see when the fan kicks on and off. Notice the drain it pulls on the alternator by the rpm dip, afr jumps and timing advances.
keeps a solid idle with shitty 1000cc injectors
Old 09-30-2015, 08:47 PM
  #131
bigodub93's Avatar
Wow it has to be something going on internally that won't let my temp drop. Or maybe just maybe it could be the temp sensor. I have a autozone one for the big sensor that goes to the gauge. And idk the condition of the small one the goes to the ecu. Maybe it's worth a try to switch it out.
Old 10-01-2015, 07:21 AM
  #132
No the ect sensor works independent from the fan switch.
When your fan turns on its should drop those temps especially at idle.
You got a legit spal fan right? The pics look just like my fan but idk.
Are you running water? Or coolant? I think you posted water wetter
Old 10-01-2015, 07:27 AM
  #133
bigodub93's Avatar
The motor has spal stamped on it so it should be real. A bought it from Amazon. And yes water wetter and distilled water. I was thinking maybe the temp I'm getting from the ect sensor may be high because of a worn sensor that doesn't have the right resistance and if it shows 190 when it really may be 165 then my fan will never cut off because the ecu still sees 190. Just a thought.
Old 10-01-2015, 07:53 AM
  #134
Yeah that could be a possibility
Do this next time the motor is idling feel the bottom rad hose
Check when th motor gets to 150 and feel it
Then again at 170
Again at 180-190
You should be able to tell when the thermostat is opening and compare that to what your ect is sending
When my fan is cycling i can feel the lower hose get hard (thats when the thermo is closed)
Then as the thermostat opens around 185 the fan kicks on again and the hose gets soft because the water starts flowing.
My temps drop and the thermo closes. Andnit starts all over again.
This is how it should work
Make sense ?
Old 10-01-2015, 10:39 AM
  #135
bigodub93's Avatar
Yes that makes sense. I know it does open but never checked to see if it closes
Old 10-01-2015, 12:10 PM
  #136
Who is Mr Robot?
wantboost's Avatar
Use a multimeter to check resistance on the coolant temp sensors and the fan switch. Granted when one goes bad they don't activate the fan.
Something is causing the fan to stay on. Either it's a wiring problem (where my money is), or it's a sensor problem.
It might come down to you chasing the harness to see if there's a wiring problem. It's possible a wire has rubbed through or something.
Old 10-01-2015, 12:35 PM
  #137
The temp he has it set to and his fan switch is keeping the fan on. The wiring is ok
The problem i see is the temp should be able to drop down to the 170s with that fan.
From what i understand, at idle his fan is constantly running and it shouldn't.
Old 10-02-2015, 02:41 AM
  #138
LightningTeg's Avatar
170s? Mine will never get below 190 on a cool day.
LightningTeg is online now
Old 10-02-2015, 04:32 AM
  #139
Thermostats arent only for cold starts
Old 10-02-2015, 05:03 AM
  #140
I'm just saying, a fan wont fix underlying cooling issues.
Old 10-02-2015, 05:13 AM
  #141
Right. Thats what im getting at
In op case the fan is a band aid to the cooling system. He can leave it as is or figure out why his engine is running so hot at idle.
david236kEG
12-19-2008 10:27 AM
ahobbs
07-29-2008 05:35 PM
fake mugen power
07-09-2006 11:14 AM
JustBlazeKid
11-11-2004 09:41 AM
Quick Reply: No air flow to radiator..... Need help!!!!!
  • Ask a Question
Question Title:
Description:
