Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   nitrous ques? (https://honda-tech.com/forums/forced-induction-16/nitrous-ques-1881369/)
jnasty Jan 31, 2007 05:51 PM
nitrous ques?
i was wondering i have a 98 integra gsr putting on nitrous.for my msd digital window switch do i need a tach adaptor? also were can i tap a wire for a ignition signal for the window switch?
what mode should it be in?
thanks
jnasty Jan 31, 2007 06:10 PM
anyone?help?
urbansi Jan 31, 2007 07:28 PM
Re: nitrous ques? (jnasty)
You for the most part are not going to get much help on here as far as nitrous goes, more people will chime in with remarks like NAWZ and shit
Honestly i think that 90% of the people that post here dont know what the hell a window switch is anyways. Attempt to contact MSD, and do some other searching online.
Sorry i couldnt be more help.
fyqprmdobe Feb 1, 2007 08:54 AM
Re: nitrous ques? (urbansi)
You dont need a tach adaptor it should all hook up in the engine bay to the distributor. The ignition wire can be any switched 12v wire, like on the back of your stereo is a common one. When the switched is turned off then on again it starts up in the mode it should be in to run, but you need to calibrate it, # of cylinders, rpm on and rpm off.
The switches are real easy to work, my nissan came with one and I figured out how to use it without any help or manuals, the buttons are cleary labled as to what they do.
