Nitrous Cam advise k20a2
Hi All,
In process of building a k20a for mainly drag, but also for occasional track days running n/a with a shot of gas.
Our power adder for the drag will be nitrous, and the aim is approx 500whp. We are running low compression, so I know I'm going to lose HP n/a, so was thinking of some cams to help with n/a performance but not loose out on gas.
I not want any issues with clearance, so if I need to use DIC to achieve this then so be it.
Spec:
Cp flat top 9.4:1
Manley rods
Supertech (90lbs) Springs, valves, valve stem seals,
S200 oil pump mod inc k24 chain, oil pan
Arp head studs
Cosmetic gasket
Acl bearings all round
Any help would be good
Cheers
Paul
Cheers
Spec:
Cp flat top 9.4:1
Manley rods
Arp head studs
Cosmetic gasket
Cheers
Paul
Cheers
Nuxinator
Engine Management and Tuning
05-20-2008 02:35 PM
