newbie question... TURBO = Goodbye AC?
Re: newbie question... TURBO = Goodbye AC? (shift2255)
Just depends on which kit you get. Some wont fit with the A/C and others will. Also depends on the size of the downpipe. Usually 3" dp require the A/C condenser to be removed. Also the deisgn of the manifold, where it places the turbo.
Kits that keeps the A/C (i think)
DRAG, Greddy, RevHard 2C, Inline Pro manifold, and SFP
hope this helps
-deepsi
hope this helps
-deepsi
Re: newbie question... TURBO = Goodbye AC? (DeepSi)
thx i just got my teg 3 days ago, 45000 miles on it, it runs great, sure beats my run down chevy pickup! im planning on turboing the ls b18 in it later when i change the timing belts and stuff.
Re: newbie question... TURBO = Goodbye AC? (TenaciousC)
nono no, you have the equation all wrong. the correct answer is turbo= goodbye money in your wallet
but you can keep your ac with most kits, the only time your gonna have a problem is if you go with a tubular or custom manifold.
Re: newbie question... TURBO = Goodbye AC? (KAMiN)
Greddy and MaxRev (and I think Drag, correct me if I am wrong) kits allow the use of A/C in most applications.
Re: newbie question... TURBO = Goodbye AC? (DIRep972)
A/C rocks I would never ditch it My rev-hard kit let me keep it after putting a little dent in the 2.5" dp.... nothing major.
Re: newbie question... TURBO = Goodbye AC? (shadowdawn)
one thing i would recommend if you run turbo and retain a/c is to wrap your upper a/c hose because i ended up burning through the hose due to the heat being emitted from my turbo. it sure shocked the **** outta me when i pulled into get dinner and i hear PASHHAHSHHHHHHHHHHh and see steam vent from underneath my hood in a large *** cloud. it inspired me to ditch my a/c as well as go with a 3" dp
