new turbo...shaft play?
I just bought a new turbo from HT member Rouge Works and it has some side to side shaft play. It is brand new and he said that it is normal...It is a garret t3/to4e. Does this sound right.....oh, there isno in andout play
Re: new turbo...shaft play? (shoebox)
It's normal to have play as long as the blades do not contact the housings. See, when under oil pressure the turbine/compressor assembly will become much stiffer.
1 Post
Re: new turbo...shaft play? (Flr Power)
same thing is happening to my brand new t3/t4. i've been told that it should stiffen up once you run it on the engine, hopefully they're right
Re: new turbo...shaft play? (XSIintegra)
im isnt solid as a rock?
it only has like 4000miles on it
even after 100miles it sitll had the same ammount of shaft play
As I said, side to side is normal, as there has to be room for oil to flow around the bearing. Axial play is a problem, you should not have any of that. Enjoy
Hoosier Daddy
04-14-2004 03:51 PM
