new stuff on but boost will not stop climbing. 16psi
new stuff on but boost will not stop climbing. 16psi*updated*
Well i got my new stuff on, But i do have a major problem. I think my Profec is hooked up wrong to the wastegate or not working at all. I mash the gas and boost just climbs. High boost bamn 16psi on the gauge i pretty much **** my pants. Then i turned it to low boost and bam 16psi. After messing the the gain and balance some i went ahead and turned the profec off, Thinking it will just run off the 6 pound spring. I mash the gas and bam 16psi at about 7000rpm and it was still wanting to climb. What could be wrong? I do have the 5.8psi spring in the wastegate.
here is the black box OUTLET circled
Now the outlet goes to the back side of the wastegate
then the vacuum hose from the top part of the wastgate goes into a "T" from the BOV to the vacuum block
here is the main picture color coded to where things are going
Thanks intec for fixing my mistakes on my setup.
Any thoughts? comments?
Modified by TacomanSI at 7:57 PM 6/20/2006
Mr. Badwrench
Re: new stuff on but boost will not stop climbing. 16psi (TacomanSI)
first off. get the stepper motor as close to the wastegate as you can. the shorter the lines the faster it will react to control boost.
Re: new stuff on but boost will not stop climbing. 16psi (boostedcivicsir)
ok so try and move the black box over to the right of the bay and shorten up the vacuum? i will work on that tomorrow? even tho i turned the profec off it should have only boosted 5.8psi correct?
you have it hooked up wrong
the side of hte wastegate is hooked upo to a vaccum port from the intake manifold or the turbo compressor
then the top is hooke dup to your ebc
so basicly switch the two hose around on the wastegate and you be set
Re: new stuff on but boost will not stop climbing. 16psi (SuperSi)
yea, you have it hooked up backwards, hence the creep you are experiencing. vacuum is hooked up to side port, EBC to top.
Re: new stuff on but boost will not stop climbing. 16psi (Si Shane)
thanks guys, i am glad it is something simple. I didn't plan to drive it agian untill that was figured out.
ok so i swaped the two wastegate hoses and it still does the same thing. boost just keeps climbing. This is with the profec off. any more thouhts?
it's probably your manifold design..I got the neukin manifold and it does the same thing..and I got a 3psi spring in it and it climbs to 11psi..sometimes 20psi good thing I got boost cut...
Re: (EF-EF)
Low boost on larger volume exhaust manifolds makes it especially difficult to control the boost pressure, especially with a small wastegate. Air flow from high to low pressure zones. Well with your large volume exhaust manifold at low boost, the exhaust manifold has an extremely low pressure. It should be very similiar to the pressure in the intake manifold. This means the air won't flow as easily out the WG because the pressure difference isn't dramatic and also the direction of the air naturally won't want to exit the WG. The answer to this is run a larger WG or two of them. That or get a smaller volume exhaust manifold. Ramhorn manifolds are often too large/long for low boost pressure and you can make significant midrange gains using something with a smaller volume.
EDIT: Sorry, I only skimmed the last post and first post briefly. The above response is in regards to the poster above me's post.
I'd unhook the EBC and see if the boost pressure is okay that way. If it is, then you know its the EBC/solenoid/that dealy. Start simple and build from there.
Re: (EF-EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-EF »</TD></TR><TR><TD CLASS="quote">it's probably your manifold design..I got the neukin manifold and it does the same thing..and I got a 3psi spring in it and it climbs to 11psi..sometimes 20psi good thing I got boost cut...</TD></TR></TABLE>
dont think that is it , fix the ebc first , also tap off the brake booster line b4 the check valve nice solid source for a boost/vac line
Re: (EF-EF)
I've had a couple Neukin manifolds boost creep REALLY bad on the dyno, but i don't think that is the problem here.
Bypass the boost controller, hook the side port (bottom) directly to manifold pressure and leave the top port open and see what it does. I didn't read the whole thing, if this has already been said, sorry.
Re: (tony1)
what size vacuum line are you running?
what size port off the Intake manifold are you hooking it up to?
I had a big block h22a here locally that was creeping, it was due to having 4ft of vacuum line going to the lower port on the tial, we upgrade the line to 7/16 and ran it off a bigger port off the intake manifold and it now holds perfect boost.
also, i've noticed that if i have an overly rich tune, i can have creep issues as well.
TurboIntegra
08-11-2001 01:23 PM
