New products in Japan
INFO: The Denso replacement 3bar map sensor for Integral AF/boost meter plugs directly into a Honda harness.
Defi just released their digital display that shows two guages at once. It also shows speed and rpm.
Greddy just released their gauges that are similar to the Defi's. Still looking for an image!
HKS just released their A/F knock amp for the F-CON V pro and CAMP. This amp gives feedback for tuning purposes.
The new EVC was also released.
[Modified by Dee, 6:24 AM 6/27/2002]
Re: New products in Japan (rjardy)
You ned to learn how to post links dude....
Here are the videos:
http://www.nippon-seiki.co.jp/defi/d...mages/o-wu.wmv
http://www.nippon-seiki.co.jp/defi/d...images/sp1.wmv
http://www.nippon-seiki.co.jp/defi/d...images/sp2.wmv
http://www.nippon-seiki.co.jp/defi/d...mages/tw-e.wmv
[Modified by MiraiZ, 8:13 PM 6/27/2002]
Re: New products in Japan (N8)
Dude that's awesome, exactly what I wanted to avoid having a ton of gauges in my car. I just hop it measures all turbo stuff too, like egt and boost.
And it doesn't cost an arm and a leg.
1 Post
Re: New products in Japan (2K_TEG)
hey Dee or MiraiZ do you know if that Defi elctronic gauge can be used alone? Or does it have to hook up to Defi's box and other gauges? For example can i use my own gauges and maybe hook it up to that?
[Modified by Cramerox, 1:16 PM 6/27/2002]
Re: New products in Japan (Cramerox)
The Digital readout replaces the stepping motor analog readout so connection to the control unit is needed.
Re: New products in Japan (Dee)
That's dirt cheap if it could take the place of an egt, boost, fuel pressure, oil pressure, water temp and oil temp. But it doesn't I bet.
Plus it needs that defi controller which I bet does cost a grip.
Re: New products in Japan (int3gra)
Just order if from places that ship to the US. It will still be cheaper than buying it in the US.
Takakaira, unlike US companies, actually applies the yen rate to the items before selling.
Re: New products in Japan (Trigun)
The Digi display will show any readings for all of the Defi link gauges and the speed reading requires an add-on box.
Exchange rate has gone to crap recently
Dee, does this do what I think it does?
http://www.blitz.co.jp/products/elec...powermeter.htm
Re: New products in Japan (kengs)
Re: New products in Japan (DarksideDC4)
crap! I thought it did the reading independent of the gauges, so I wouldn't need to buy all of them. Too good to be true.
[Modified by 2K_TEG, 2:42 AM 6/28/2002]
That power meter is kinda gimmicky but it somewhat works!
The Control box is needed to do recording, set warnings, control peak/hold and act as the datalink interface for all gauges.
