New forum member turbo querey
Hey guys! this is my first time posting on this forum, im happy to be here.
I have a question regarding my turbo setup. i currently own a jdm 96 spec integra type r. i have purchased a turbo kit from canada and plan to run the kit at 6psi on a stock engine i have an fc power commander ECU and intercooler. many people form the UK have told me it will blow up in less than 1000 miles even if its mapped correctly. im just after some info regarding boosting a stock motor and also if any one here has done it? thanks in advance ck |
Re: New forum member turbo querey
If you did some reading on here you will find that other members are running over 350hp on stock blocks quite safely.
What idiot in the UK told you your engine will blow up? |
wow thats massive power! i was told by quite a few people actually that if you run over 6 psi 250 bhp it will blow up due to high compression ratio
i would be happy at 6 psi ...honest :P yup been reading on here under the FI section unfortunetly most of the links im after are broken. some really good info on here!! Well intresting thanks! |
