new b18c1 turbo build
hey guys. i dont really post on here but i do read alot of everyone topics. very intresting point of views. i was just wondering if you guys tell me if my set up is good for 400hp.
b18c1 stock sleeves
type r oil pump
8.5:1 JE 81 std pistons w/ je rings
acl race rod, main, thrust bearing
stock rods
b18c1 head port and polish
3 angle valve job
supertec dual valvespring, titan retainer
big ebay intake manifold
denso 720cc injectors
turbonetics 60-1 turbo {.60 .63}
log manifold
turbonetic wastegate
JRC FMIC
my suspension wont matter but will help in 60 feet
Omni full drag suspension
full tractionbar
blox lca
nrg engine damper
please dont bash on me. i just want to get some feedback from everyone.
b18c1 stock sleeves
type r oil pump
stock rods
3 angle valve job
log manifold
JRC FMIC
full tractionbar
blox lca
nrg engine damper
HT White Ops
Re: new b18c1 turbo build (oneracer)
save the money on the port and polish its not going to make a world of a difference and besides that you can spend the money elsewhere. trust me for 400whp you don't need a port and polish your just spending more money that could be used elsewhere. why not use the money and get your block sleeved just to have that piece of mind? 400 is possible on your stock sleeves don't get me wrong. would I advise it? thats another question. stay away frpm any egay parts, you thank yourself in the long run or short run which ever comes first. also, I would bump your comp up to 9.0.1 it won't take as much to get you where you want.
Re: new b18c1 turbo build (SD_Lurker)
thanks. i going to run this set up for this season and see how i do. i want to get a sleeve block in the furture.
The sleeves get a mixed review all the time. I chose to spend the extra grand and have it done mainly for that extra piece of mind but also what the future holds. I may get the itch to buy a larger turbo or simply crank it up. Either way, it's built for it. My opinion is to spend the money on building the block as best as possible. Intakes, etc. can be bolted on in the backyard anytime. Having to remove the engine again is just a pain and cost more in the long run.
I see you listed some traction items. What about an LSD? I don't see it listed and at 400hp, you'll want one.
One side note, I've seen people try to get extra $$ by selling Type R parts. In regards to the oil pump, GSR or Type R.....exact same part.
The options are endless but having a solid foundation is key.
