Need some pointers before I get my JRSC LS dyno tuned
I just got my JRSC for my LS two days ago!I found a good deal on craigslist. I have compiled a bunch of parts. So far I have a hytech style header(4-1 ,2.5'' collector) aem short ram, 2.5'' custom exhaust, aem cam gears, b16 tranny, b20 crank pulley. My question is im gonna get my teggy dyno tuned in the next week or so but im in california so I cant get all the fancy progams you guys have do you guys think the apexi neo AFC will do? Also what other upgrades would you guys recommend before I go get it dyno tuned? Upgraded injectors maybe? Thanks
Re: Need some pointers before I get my JRSC LS dyno tuned
I cant use the s300 because I have to keep my stock ecu they only make them for obd1 and im running obd2.What size injectors sould I get 310cc or 440cc?
Moderator in Chief
Thats still not an OBD2 Ecu. Thats an OBD1 ecu with the OBD2 adapter harness built into the connector. He needs an OBD2 ecu to pass inspection. All he can use are piggy backs like Greddy Emanage, AEM FIC or Apex AFC.
Who is Mr Robot?
Myou can run a jumper harness and a chipped obd1 ecu... just swap back before emissions and drive around. It's what I do
The main issue is that you have to have larger injectors to support the power the jrsc will make. It won't work on stock injectors. You also need an upgraded fuel pump.. a walbro 255 is all you need and they are cheap. .. again because a stock fuel pump won't be able to provide enough fuel
Do it right or don't do it at all. You can't run a jrsc with stock injectors and fuel pump. There just isn't enough fuel and honestly your tuner wouldn't waste his time tuning the car
Who is Mr Robot?
I do know the aem fic, as a piggyback has more capabilities than the emanage and a much better support group online. They tend to go fairly cheap on eBay if you find one from a private seller
OK thanks guys I will definitely look into the AEM FIC piggyback. Also do any of you guys know if the LHT intercooler mod is legal to do for us CARB guys in California?
Who is Mr Robot?
Nope..
But if you have the sticker for the supercharger then most refs are ignorant as to everything else that's been done to the car (usually)
Yea I figured it wouldn't be smog legal. Im so sick of living in Commiefornia I envy all of you.
Who is Mr Robot?
^listen to this man, he speaks nothing but knowledge and truth when it comes to JRSC setups
Do any of you guys know what the actuall size of the stepper pulley is? I heard I'm better of running the stepper pulley over the b20 crank pulley.
R.I.P. Mark
endyn / mvm = + 12%
ASP racing = + 14%
if your trying to work it out
down load the calc from Veris site
" compression version " and plug in the right numbers
remember that you must watch the heat output and blower speed
also remember ring lands like to break on stock pistons above 12-13psi
http://ftlracing.com/JRSC_calculators.htm
ASP racing = + 14%
xtremecivichb
05-07-2003 07:31 PM
