Need some help!, I think I may have ordered the wrong catch can...
Hi guys,
I wanted to double check with you guys to see if this is the right part. Someone suggested that I buy the MOROSO CATCH CAN from summit racing. I went to the site and type that in the search and only one item came up. I figured it was the right part so I added it to my basket.
Today I went back to summitracing and went over my order again and saw the description on the part. Does anyone know if this is the correct part number for a oil catch can? I dont think it is because it says coolant catch can...
http://www.summitracing.com
MOR-63660
Aluminum, 9 in. high x 3 1/8 in. diameter, recirculating catch can
Keep excess coolant where it belongs--in your car. This Moroso aluminum catch can holds up to one quart of excess fluids and recirculates it back into your coolant system. It's NHRA, IHRA, and SCCA-accepted, measures 9 in. high and 3 1/8 in. in diameter, and it comes with a push-lock fitting, barbed fitting, siphon tube, and drain fitting.
I need to know right away, I ordered this stuff yesterday, and if I'm lucky I still have time to get a confirmation from you guys and I can call summit and change my order.
thanks
MOR-63660
thanks
Re: Need some help!, I think I may have ordered the wrong catch can... (Sleeper)
MOR-85470
hehehe, j/k thanks for giving me that part number...unfortunately my stuff already left summit, but at least I know which part to trade it in for.
thanks again
BadassEFdriver
06-20-2011 06:12 PM
integraver
06-02-2004 12:21 PM
