need opinions on reworking my block..
right now i have a gsr block with darton sleeves, how much can i bore this block?? and which mm pistons should i go with. All opinions are welcome.
Re: need opinions on reworking my block.. (B00STeD)
You get the pistons that match up the bore. I say stick with stock bore (81mm). The reason I say stock bore is that you will have more room to play with in case somethign happens to the walls.
Even though 84mm turbo hondas feels really,really good.
as long as you don't pound the **** out of day in and day out you can safely go to 84.5mm, at least that's what i was told and am doing.
well if you go 84.5 and do happen to mess something up . you will have to replace that sleeve. now i dont feel to comfortable pulling out one sleeve and replacing it being that all the sleeves sit against each other and that might disrupt their original seat. then again thats what i was told by a very reliable source.
if you go 81mm then you have more room for error.
[Modified by eviltwin, 8:52 PM 9/26/2002]
Spade
12-21-2001 11:33 AM
