Need opinions for best burn out method
New User
Sup guys, well I will finally be hitting the track this Friday with VTC_civic to see what my biatch can do down the track, unfortuneately no slicks but I got drag radials at least. Questions is I usually just did a quick burnout to get rid of any pebbles, gravel etc that's on there but would really like to heat em up but never get the hang of it? Any method or procedure you guys can share that will work best since I rarely visit the track. TIA,
Nick
Nick
New User
Re: Need opinions for best burn out method (VaporTrail)
center force dual friction... what's your opinion on that?? It's worked great and holds up awesome but 2nd opinion never hurts,hehe. thanks John
Nick
Nick
the way i do a burnout in the race car is like this .... have someone stage you little pass the waterpit roll through get your tires wet. then about ft past the water hold your ebrake shift into second gear and rev to around 7500-8000 rpm jjust turn the wheel left and right when you feel the car going foward release ebrake.
Re: Need opinions for best burn out method (b18bturbo)
Re: Need opinions for best burn out method (D-Man)
turn your wheel left and right?!?,why? to warm up your CV Joints lol,anyway i wouldnt turn it left or right,good way to snap an axle,keep it straight.
Re: Need opinions for best burn out method (jamal-188)
the reason you turn it left and right is to get the slicks warmed up evenly. But its really how you drive too. Most times there not enough time to warm them since they grab so quick. You dont want to be stuck there burning out forever either as soon as the car grabs traction realease the ebrake or what ever staging brake you have.
Re: Need opinions for best burn out method (boost killz)
if you have the early bfg drag radials or the nitto's, don't heat em up too much. if you have the new g-force bfg's, then heat em up more. and be careful turning your wheel doing the burnout, because i've seen some inexperienced people almost hit the wall doing hit. lol. you should be looking for consistent 2.00 60 ft's realistically.
oh yea, definatly do the 2nd gear burnout.
[Modified by jinxproof99, 5:13 PM 3/13/2002]
New User
I thought you weren't supposed to run through the water if you have regular tires on....Is that true? I guess we are just talking about DRs and slicks here...
New User
Re: Need opinions for best burn out method (sgT)
Yeah I am definitely staying away from the water, and Jnx thanks for theinfo o the nittos since that's what I am using. I'll post times and maybe video courtesy of VTC if he decides to film. Thanks a bunch fellas
Nick
Nick
with the nitto's i'd try around 22-24 psi in the tires and launch around 4000 rpm's slipping the clutch. no water and a quick burn out. 1st gears good enough. just for a second. to get the **** off and get em alittle sticky. too much and it'll work against you. just my experience. good luck.
Nick
Nick
Re: Need opinions for best burn out method (VTC_CiViC)
whats up with the 2nd gear burn out , i never heard of that before?
i do the sameas b18 turbo but with 1st gear
Re: Need opinions for best burn out method (itr206)
reason i do it in second is less strain on my motor. Remeber i got full race stup an the gear is juts so short its just puts uncessary strain on my motor.
when i use to race on street tires ill start burning them in 1st and then ****** 2nd and really smoke them and i got long gearing i run the accord tranny 2nd gear take me to about 73mph@7700rpm's
but best i could get on street tires was a 2.2 60foot
and i got a 1.8 on slicks before
this was before i was turbo
