Need To Know What oil Restrictor, Dyno graph inside
I have a B16 with an ebay t3/t70 on it. Motor is completely stock from the oil drain plug all the way up to the oil cap. I need to know what size oil resctictor to get for my oil feed line going to the turbo. i believe i have a 4-an line going to it.
What size oil restrictor would be necessary?? Thanks in advance for help
^the dyno used was a Dynamics Dynameter a.K.a THE HEARTBREAKER which is said to read anywhere to 10% to 15% lower than a regular dynojet
Re: Need To Know What oil Restrictor, Dyno graph inside
will this reduce the pressure enough? i only want the turbo to see about 30 psi tops. i would rather just get a restrictor the replace my line. i already blew my turbo seals once cuz of too much pressure i believe. replaced all that but i want to get the oil pressure down before i run it anymore
Restrictor diameter of .065 hole size should suffice
http://www.spoolinperformance.com/in...89033fab86f929
sampol999
09-03-2006 01:09 PM
