Need help with my turbo
I have 2 problems, what should i do? can i fix it?
1. a lot of shaftplay
2. exhaust side housing is cracked...look
zoomed in...
Modified by TrunkRattlin at 6:11 PM 4/29/2006
zoomed in...
Re: Need help with my turbo (TrunkRattlin)
The rebuild kit would take care of the shaft play, the new exhaust housing would take care of the cracked one.
Sounds to me like that would work.
Re: Need help with my turbo (dandizel)
does the turbine hit the housing? like if u pull the turbine and spin it at the same time, does it scrape?
if it does the turbos garbage.
if not. bolt it on and run it, those cracks wont effect anything.
Re: Need help with my turbo (shortyz21)
Yep those mitsu turbos "feel" pretty sloppy even when they are fresh, like the guy above me said if the blades don't hit, run it.The turbine housing is nothing to worry about either, it might affect spool a little bit due to exhaust pressure escaping through the WG flapper but it should work just fin other than that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrunkRattlin »</TD></TR><TR><TD CLASS="quote">the blades do hit when i moved the turbine and it touches the housing..</TD></TR></TABLE>
toss it in the trash can
Re: Need help with my turbo (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> toss it in the trash can </TD></TR></TABLE>
DOH! That's your biggest worry. My turbo had cracks on the inside of the exhaust housing like that too but I ran it, no problems yet.
Re: Need help with my turbo (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">Buy a new turbo.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">Buy a new turbo.</TD></TR></TABLE>
