Need help with F22b1 Turbo Accord ECU Questions
* B A N N E D *
1 Post
Help!!!!!!!
Ive searched... but cant find a CLEAR answer to a (couple of) question(s) I have:
I am about to install all of the **** ive bought over the past couple of months to boost my f22b1 accord (OBD1). Ive got just about everything minus a couple little things here and there (im sure there will be more little stuff with the install as well)...
My question is what ECU should i run with this thing??? I have to have either socketed right??? At this point... Could I then run Uber, Crome, or Neptune??? THEN convert to RTP when it FINALLY comes out...
A friend of mine was sayin a P28 was the way to go (I plan on running Neptune or Crome untill Neptune RTP comes out). Im having INTEC in Kent,WA tune it.
My dilemma is that I already have a Virgin OBD1 P72 ECU out of a GSR swapped Civic a fiend of mine gave me, as it has a knock board, I am not sure if it is compatible with my engine/turbo setup. Ive put alot of time into researching my **** on this forum, and this is pretty much the last issue i have that has got me really puzzled. I have gotten LOTS of good info, and need your guys HELPPPPPP!!!!!
What should I do??????
Thanks!!!!
Spike
Thanks!!!!
Spike
Re: Need help with F22b1 Turbo Accord ECU Questions (bigdaddyvtec)
