need help on a dsm resistor box install obd1 / obd2
alright, i got an
obd1 del sol with an obd2 jdm sir2 b16a and usdm gsr engine harness, with a chipped P28
i got dsm 450's and now im installing the dsm resistor box.
*****on the drivers side shock tower, there is a dead end plug, is that where i need to run the resistor box?*****
*****i heard that on obd2 engines the dead end plug for the injectors are under the intake mani. or is this where i need to run it instead?*****
thanks for all the input! still gotta a lot to learn.
Re: need help on a dsm resistor box install obd1 / obd2 (TeamNIR)
Using the search function will find your answer :-)
https://honda-tech.com/zerosearch
There is a diagram on http://www.phearable.net/tech/....html that will help you
i mean, all i really need to kno is if i use the shock tower plug or the one under the intake manifold, i guess, ill just do the one on the shock tower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNIR »</TD></TR><TR><TD CLASS="quote">i mean, all i really need to kno is if i use the shock tower plug or the one under the intake manifold, i guess, ill just do the one on the shock tower </TD></TR></TABLE>
Time to bust out the multimeter. I would never attempt the install without knowing for certain I am cutting the right wires.
Black R
08-31-2003 03:05 PM
integranator
04-07-2003 06:59 PM
