need help with dohc zc turbo crx
Old 04-20-2007, 01:22 PM
ximportman's Avatar
Default need help with dohc zc turbo crx
need some help peoples..heres what im workin with
hf manifold
ford thunderbird turbo coupe turbo
3in downpipe
xs power type hrfl bov
aem fpr
stock injectors
stock ecu
brand new zc ecu, cuz my old one shorted out and melted my rotorand what not
ok well i just got my turbo set up and when the car is cold it takes a couple cranks for it to start up, but once it warms up it starts right back up once shut off, but also when i first start it up it idles at about 1500rpms, then as it warms up it drops down to about 900 then it goes back up to 1200 and goes back and forth, also it smokes just a lil bit of blueish smoke when i start to rev it..if anyone can help would be great..thanks
Old 04-20-2007, 09:54 PM
ttracing03's Avatar
Default Re: need help with dohc zc turbo crx (ximportman)
are you using any engine management..crome, hondata,etc.. I had the same problem(idle) sounds like you need to get it tuned. Good luck
Old 04-21-2007, 09:47 AM
ximportman's Avatar
Default Re: need help with dohc zc turbo crx (ttracing03)
nobody knows
dailyekhatch
11-28-2007 12:52 AM
ximportman
04-15-2007 01:35 PM
Starscream
06-15-2004 07:16 PM
Quick Reply: need help with dohc zc turbo crx
