NEED HELP ASAP...turbo leaking oil!!!
Honda-Tech Double Platinum Member
We just got through with my install and i have 2 problems. First off...one of the bolt holes to hold my oil pan onto my block got stripped. We just put copper gasket maker in it to stop it up but i dont think its gonna hold. Second...and most important part is my turbo is leaking oil from the hot side into my DP. Why is it doing this? Im guessing that the seals are blown on my turbo and its leaking into the exhaust...i havent checked if its getting into the compressor side or not but im sure it is. Whats the problem here and how do i fix it? Thanks.
Sean
Sean
Re: NEED HELP ASAP...turbo leaking oil!!! (Acura_I-RS)
DAMN IT!!! Is it safe to drive like that for a while? Cuz i really need this car running. How much does it usually cost to get one rebuilt? DAMN IT DAMN IT DAMN IT!!! Sorry im just a little pissed. Thanks
Sean
Sean
Re: NEED HELP ASAP...turbo leaking oil!!! (sCeRaXn)
Can i atleast take it for a test drive? I know its gonna smoke alot but i want to see what im missing. Thanks
Sean
Sean
Come on people...i need some answers here...lol. I know that someone has been through this before and can help me out. Thanks
Sean
Sean
ttt...i dont usually bump myself like this but i need help fast.
Sean
Sean
Re: (TeStUdO)
Thanks for responding! What will it hurt if i drive with them like that for a while? Do you think its definately leaking into the compressor side if its leaking in the exhaust side? If its not leaking into the compressor side i dont think it should hurt anything...but i know it will smoke alot. What will happen if it is in the the charge pipes...im guessing oil will get into the combustion chamber causing mad detonation?
Sean
Sean
ludelvr
05-01-2004 11:05 AM
