need help asap, please help ohh wise ones
taking off the turbo today, was wondering if can keep the 440cc's and use the VAFC and adjust the fuel pressure to still idle and use as a daily driver? was thinking -50% across and maybe idle fuel pressure of 35psi? would this work??? thanks in advance.
Re: need help asap, please help ohh wise ones (98civicEX)
right now my d16z6 is NA, running cleaned and flowed 450's with only a FPR. it idles VERY well, almost perfect and runs perfectly fine with approx. 30-35psi fuel. no afc.
1 Post
Re: need help asap, please help ohh wise ones (ion_four)
yea, low 30's should keep the car running a bit rich at idle and it will work for the rest. You may starve momentarily w/ a sudden throttle stab but the degree is hard to generalize. I wouldn't recommend it as permanent setup nor an ideal performing one. Get a run and you'll be suprised at the a/f you running throughout the powerband.
Re: need help asap, please help ohh wise ones (tonydatyga)
I wondered this too, But these people did it. Yeah, wouldn't recommend long term
https://honda-tech.com/zerothread?id=227340
Re: need help asap, please help ohh wise ones (Pelican)
well it's running, i couldn't get the FP lower then 40, i guess it's the 255lph fuel pump...but i'm running at -35% across on the VAFC and it seems fine, i'm going to try -42% across, we'll see.
bigedx
04-17-2004 08:00 PM
turbod16y7vtec
11-02-2002 07:43 AM
