Need help ASAP! - Moroso oil pump and Lovefab SST
Does anyone know if the Moroso single stage oil pump will fit on a GSR using the Lovefab manifold and a T3/T04R turbo? Will the turbo clear the pump?
I need to know this cause I'll be ordering the pump soon. If it doesn't clear then I might have to search for something else.
In advance thanks guys.
1 Post
Re: Need help ASAP! - Moroso oil pump and Lovefab SST (B16A1-EF9)
Is this for a dry sump system? That places the pump where the AC compressor used to be? If so, then probably not. You could always mount the pump elsewhere I spose...
