Need help asap...car keeps cutting off for no reason!!!
Honda-Tech Double Platinum Member
My car keeps cutting off on me for some reasons....it seems to happen at lower rpms when im cruising down the road. Im running an open downpipe right now and i know that im running rich as hell. I took out the spark plugs and they looked pretty bad so i got some new ones...but it didnt help. If i let the car sit for a few minutes itll start back up and go again...but theres no telling how long it will run before shutting off again. This **** has almost stranded me like 5 times now...i need your help asap. Thanks
Sean
Sean
Re: Need help asap...car keeps cutting off for no reason!!! (sCeRaXn)
Well i just went and checked my codes and its throwing a code 15...which is ignition output signal. What could be causing this? I hope that its something that is easily fixable and cheap cuz im broke as hell. Thanks for the help
Sean
Sean
hey man sorry to hear about you bad luck..... but, i have had a coil do this to me several times on diff. cars... you might want to check that and check the wires comming from the ingition switch.... other than that.... you got me
Re: Need help asap...car keeps cutting off for no reason!!! (warchild69)
Thanks for the reply...ill go check that out. Any other ideas?
Sean
Sean
gsrauto98
20
05-21-2010 08:59 PM
