NEED HELP ASAP!!! 450CC INJECTORS!!!
I'm going to pick up some DSM 450CC injectors today so that I can do the AFC "HACK" since the missing link won't work on my car...but anyways...i have two questions
1. do I need a certain model injector...or as long as they are dsm 450cc
2. do I need the DSM clips or do my original clips fit
btw, this is on a 92 JDM H22A.
please reply ASAP!!!! THANK YOU H-T
Re: NEED HELP ASAP!!! 450CC INJECTORS!!! (teameracer3)
I've used blue top injectors from a 93' GS-X that are rated at 450cc. About DSM clips that fit, they accept a pretty common clip. I was too lazy to find some in the junkyard so I just went to the Mitsu dealership and picked up a set of clips for around 25 bux. You can find them much cheaper if you look hard enough, but I was in a hurry.
90-94 turbo cars with the MANUAL transmission had 450's, and ALL turbo cars from 95-99 had 450's.
The spray pattern on the 95+ injectors is different, but that does not matter.
Re: (kpt4321)
Use your stock clips for a nice clean look. The dsm injectors have a little tab on them that you will probably have to grind of with a dremel or cut with a razor blade. Once you cut the tab, the stock clips plug right in.
Re: (BoostedD15B7)
to get rid of the tap in the injectors so you can use your stock clips, I used a blow torch to heat up a piece of coat hanger and melted the tab clean off, easy and took a few seconds.
Blue top 450cc is 1st gen eclipse
black top 2nd gen
don't remember what the post said about resistor box but don't forget that little guy!
black top 2nd gen
spotscivic
11-23-2007 08:20 PM
