need bearing help - boosted f22b1 build
i just tore down my block today. i am confused however about the rod and bearing numbers.
they are as follows
MAIN
1 /// 2 /// 3 /// 4 /// 5
da 95 /// da 95 /// da 95 /// da 95 /// da 95 block side bearing
4 95 a1 /// 2 95 j1 /// 4 95 e /// 4 95 a1 /// 4 95 e
4 95 e /// 2 95 j1 /// 4 95 e /// 2 95 e /// 4 95 e girdle side bearing
on the block casting it says CCCBC, but my helms says it would say something on the crank but it is like a serial number - its not like what they describe in the book.
RODS
1 /// 2 /// 3 /// 4
4 95 k /// 4 95 j /// 4 95 k /// 4 95 k pin side bearing
4 95 k /// 4 95 k /// 4 95 k /// 4 95 k cap side bearing
and they are all stamped J 2
any ideas? i am going to see what my machinist says first. obviously my next step is getting the block cleaned up, bored and honed. also my crank looks great. all the journals look fantastic, but i am still going to have my machinist check it out and possibly polish it.
EDIT - i found new numbers and letters on the crank CCCB and 42343, rod and main respectively
they are as follows
MAIN
RODS
1 /// 2 /// 3 /// 4
