need advice about B18c4 turbo
Hi guys, I'm a UK based member and I was hoping someone on here could give me a hand with turbo charging my B18c4 swapped 'teg Si.
The B18C4 in basically the same as the Integra Si/GSR B18C. I'm looking to run around 280-300whp on standard internals.
The car is in the process of being 'tucked and shaved so I plan to run a backdoor configuration intercooler.
What I was looking for advice with what size piping to run for the intercooler, what turbo the use and what size injectors? I'll be running a Hondata S200 with loads of extras.
Thanks for any advice in advance guys.
Tom
Tom
Re: need advice about B18c4 turbo
Since you are in Uk you'd better be off with a Hondata S300 , much more easier to tune. As for the rest of your questions you'd better off searching on this forum, there are so many threads that has useful info. I would go with 2.5 inch piping for your IC , 750cc injectors so there will be enough room if you ever wish to go higher whp. and as for a turbo there are many choices to go for , I would choose a bigger one with the same thought of going bigger down the road.
drvfast
02-17-2004 06:21 AM
deftones0817
11-14-2003 07:40 PM
