Re: mynameisjustin and here is my CRX B18C1 GT2871R Build Thread
Gave 2nd gear 10psi yesterday and she spins but accelerated quite nicely. Plugged in my BBG table we built and on the street she loads quite a bit more. Immediately hit boost cut (18psi). A third gear pull starting at 3k and quickspool set to 12psi it pulled great and loaded up to 17psi settling at 16 which I’m happy about. Guess the dyno just didn’t quite load as much as street. During a shift from 2nd to third and the quickspool on he smashed boostcut so I may need to lower it since the turbo spoils pretty quick anyways.
I had same issue, no boostcut reached on dyno. Once on the street hit boost cut like crazy. Slowly adjust your DC down. depending on how you were tuned you may be able to increase boost cut but you will need to check with your tuner ( I always tune for higher pressure ratios and increase cut slightly over what I target) different roads and ambient temps will cause the controller to act slightly differently day to day
Originally Posted by mynameisjustin
(Post 52096279)
edit...noticed my comment today was the exact same as the last one I made.
Great work |
Originally Posted by Txdragon
(Post 52097263)
I kinda skimmed through your post here again and still didn't see mention, (I may be getting old. Lol) what engine management? Hondata, Neptune?
He wrote down the duty cycle for boost levels during the pulls. I plugged them into the chart but was over boosting on the street. Tweaked them a bit today along with the compensation table. My boost cut is at 18psi. Just did some short full throttle pulls in third to see turbo spools on on a log. Hard to find on the internet as everyone uses bigger turbos but is 340wheel good for a gt2871 on a GSR lol. Regardless the car feels great and AFR’s are good in the 17psi realm. Tuner said I’m good to 18psi.
https://cimg6.ibsrv.net/gimg/honda-t...496776283.jpeg https://cimg8.ibsrv.net/gimg/honda-t...070c85ced.jpeg She builds as high as 17.7 but holds at 16.5 on the street. I’ll get a full pull log in the upcoming days |
Pro tip feed your AFR's into your s300 makes datalogs infinetly more useful
Originally Posted by 2kdrift
(Post 52098431)
(Post 52098431)
https://cimg7.ibsrv.net/gimg/honda-t...4a18339c3.jpeg |
So maybe I'm just bored and overthinking stuff. I went over the last dyno pull that basically made 340/220. it hits 17.2psi @ 7440 and then peaks at 17.4 but drops to 16.7 @ 8100 and rides that out to 8600rpm. On the street, she hits 17psi @ 6000rpm and grows to 17-17.7 until 8100 and drops to 16.8 which rides that out 8600rpm. So on the street, she makes the 17psi 1500rpms earlier than the dyno. From what I've read and that's tough because people will say oh I make full boost by XXXX rpm but are they actually logging and looking or what which I will never know. The car drives and feels great I'm just wondering if I should have faster spool / more power than what I'm making. Are my Tuner 2's to big of a cam for this setup...really contemplating tweaking the cam gears as I just degreed them to the centerline and have left them. Some folks say overlap is good, some say it is bad...sorry for the rant just pondering things :)
(Post 52116099)
Oh yeah I 100% get ya, so I may be closer to say 350wheel but the cars just not “loading” as well on the dyno. So in your case your building more boost earlier with a bigger turbo I believe. I do know it was also tuned “conservative”. I should just enjoy driving the car which I do but I’m just a tinker person :)
(Post 52116113)
(Post 52116099)
Spool seems slow given turbo your using I hit 17 psi between 4.5 to 5.k on same motor larger turbo itr cams.
Have u done a proper boost leak test? Your cams seem a bit large given turbo used but I don't think it would cause this particular issue |
Originally Posted by GEN2 LS
(Post 52116872)
For a turbo your size I'd say the Tuner 1's would better suite your setup. Or just ITR/CTR's cams.
(Post 52116975)
Something doesent sit right with your spool time should be spooling twice as fast imo.
Boost leak test get a pvc end cap and drill a hole to mount the air compressor fitting then attach to turbo inlet. Regulate compressor air pressure to 5 or so psi higher then max boost. Get soapy spray bottle and test all fittings. First time I did this I had alot of small leaks at piping fittings and even intake manifold especially the thermal gasket |
(Post 52117379)
cam settings might change things abit (i would say set at 0,0) however I haven't had much spool differences when playing with cam timing. this is on ITR cams which do have some overlap but not quite as much ans the Tuner 2's...
you could always sell your cams even if you take a loss just bite the bullet - GSR cams are cheap and would probably overall perform better with the given setup |
So I performed a boost leak test and the tester wouldn't even build any pressure. I found a leak by the IACV so I fixed that up and then the gauge started to read. I also went from a red tial wastegate spring to a yellow so I should have maybe 10lbs of boost on the gate now. Changed it to see if it aids in a different spool time, also noticed when I degreed the cams I did the intake centerline to 94 degrees. Skunk 2's site for the exhaust says 105 degrees as the rest of every retailer selling them has 112 degrees. I degreed the exhaust to 112 degrees and got my +3.5 degree on the cam gear. Dyno graph still has a great smooth linear powerband but ill report back if/how much fixing that iacv leak helps. I think I may just be chasing nothing unless these cams are making it spool slower but yet still smooth.
Not sure what you mean by tester won't build pressure. There may be something at play here. Iirc I used my boost gauge to monitor pressure.
Did you use soapy water? That should show u whats going on spray it anywhere you can think of |
(Post 52119078)
It will bleed off from opened valves out the exhaust.... You need a air compressor set to target pressure.
so it gives conious soure of air - no fill valve just set your compressor to regulate pressure |
(Post 52119202)
So set the compressor, wife held it filling and boost gauge slowly crept up to 20psi and stayed as long as she stayed putting air in. Removed it and it slowly bled out. Going to try it again tonight and start spraying everything with soapy water because it appears and sounds like no audible leak except the air going through the pipes.
in the event I don’t find any I’m going to assume the tuner 2 cam just is to big for the GT2871r. Granted the powerband via the dyno is 100% linear like an NA car so that’s great. Just at say 16psi with a smaller cam I would probably maybe maker a bit more peak horsepower assuming it would spool faster. If I did that than street traction would be more of a battle I assume. |
