my semi fully built LSVtec (Lots of pic)
After cracking all 4 ringlands couple of months ago on the dyno.
https://honda-tech.com/zerothread?id=1466413
I ended up with this new setup after months of saving up.... aimming to hit 400-500hp on pump gas and 300+tq. It will be dyno tune by Jeff Evans on June 5th.
only thing that is worring me is the ACT xtss clutch for 300tq+
Benson Sleeve B18b
83mm bore
9:1 CP Pistons
Eagle Rods
ACL bearling
balance and polished crankshaft
Golden Eagle LSVtec Conversion Kit
Golden Eagle GSR Head Studs
Z10 catchcan Kit
B16a 2nd gen Head
SuperTech Valve tran
ITR Cams
BDL cam gears
Hondata Intake Manifold Gasket
AEBS intake manifold
.043" Copper O ring Exhaust gasket
RDL Ramhorn
38mm wastegate( low boost with boost creep is going to be fun)
3" dp
3" Exhaust with magnaflow muffler
SC6152e
precision 750hp intercooler
Precision 1000cc injectors
gm 3 bar map
Greddy profec B spec 2 EBC
Modified by komat at 1:24 AM 5/16/2006
Modified by komat at 5:20 PM 5/16/2006
Benson Sleeve B18b
83mm bore
9:1 CP Pistons
Eagle Rods
ACL bearling
Z10 catchcan Kit
B16a 2nd gen Head
ITR Cams
BDL cam gears
RDL Ramhorn
3" dp
SC6152e
gm 3 bar map
Re: (komat)
looks a little more than semi-built to me .
very nice setup, i think you will be 150% satisfied with the motor and the tuning. i look foward to seeing what you put down
Re: (blackeg)
nice stuff komat. i still have ur intercooler. the driver side is hot to the touch, but the passenger side is cold to the touch. i guess that means its working.
Re: (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R »</TD></TR><TR><TD CLASS="quote">nice stuff komat. i still have ur intercooler. the driver side is hot to the touch, but the passenger side is cold to the touch. i guess that means its working. </TD></TR></TABLE>
thats good to know
i upgraded my intercooler again...
went with a precision 750hp one this time
got a kick *** deal from Neukin.
my supertech valve tran comes in this friday. thanks to earl
tearing apart my b16 this weekend and hopefuly i have the motor all togather by next wed to start up the car.
thats good to know
Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">someone doesnt know the meaning of 'semi'</TD></TR></TABLE>
i ment to say semi-fully :-D
it could use better rods or port and polish head:-D
Re: my semi fully built LSVtec (komat)
i think the xtss is rated to like 310 or so ft/lbs. i remember it was about the same as the hdr6 setup.
even if its slips, you already have the xtreme pp, and are just a 120 dollar disc away from holding tons of power
Re: my semi fully built LSVtec (blackeg)
yea im planning to upgrade the street disc to a 6 puck spung
but having a hard time fimding a place that just sell 6puck spung disc
Re: my semi fully built LSVtec (b18sihatch)
now all you have to do is learn to drive...............you are gonna have a 450 whp sidewalk clearing pedestrian steam roller
bump cause i gotta take a day off work to drive over to evans with you and for selling me your old setup for my em1
Re: my semi fully built LSVtec (urnotfast)
pulling the b16 motor out htis weekend
and the new motor shoudl be in by wed
will take pics while i do that
