My new turbo setup in my EF (lots-o-pics)
Old 06-15-2003, 01:15 PM
shotty's Avatar
Default My new turbo setup in my EF (lots-o-pics)
All on a b16a2 stock internals........more listed after all the pics
new turbo and mani on the floor- Garrett t3/t04e .48 ex, 60a/r, 57 trim turbine, stage 3 compressor wheel
new intercooler from TJN115(ebay) mounted on my car- lots of cutting
jimfab front x-member installed - not yet tightened down or adjusted
oil return - earls fittings -10 AN
new place for my overflow tank w/2000 civic radiator
lower bracket for my radiator
overflow tank and lower radiator brackets
oil filter relocation
top pics of eveything
I have 3" stainless exhaust on the way. I have 2.5" mandrel bent charge pipes sitting here ready to be cut, fitted, welded together, and put on. Other parts include
zdyne gold secu
450cc injectors
blockguard
3mm blitz head gasket - may be coming off and getting a thinner - maybe 1mm or 2mm
aluminum retainers + stronger dual valve springs
stock cams
aluminum flywheel
driveshaftshop stage 4 axles
6 puck sprung hub clutch disk with 80% over stock pressure plate
ys1 tranny-----soon to get lsd when I get the money
apex avc-r boost controller
apex dual chamber bov
tial 35mm wastegate
thats all I can think of right now.......
Let me know what you think
Old 06-15-2003, 01:49 PM
New User
Trak_Day's Avatar
beautiful man looks great! Good luck with everything
Old 06-15-2003, 01:50 PM
JAY
JAY's Avatar
Default Re: My new turbo setup in my EF (shotty)
looks good....what kinda boost u plan on running?
Old 06-15-2003, 01:59 PM
95TurboLS's Avatar
Default Re: My new turbo setup in my EF (JAY)
sure that oil return is gonna drain right?
Old 06-15-2003, 02:12 PM
speeddave's Avatar
Default Re: My new turbo setup in my EF (95TurboLS)
thats sweet man, let us see how it comes out...
Old 06-15-2003, 02:40 PM
ucacrx's Avatar
Default Re: My new turbo setup in my EF (speeddave)
coming along nice
Old 06-15-2003, 03:45 PM
shotty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TurboLS &raquo;</TD></TR><TR><TD CLASS="quote">sure that oil return is gonna drain right?</TD></TR></TABLE>
Sure...why not? It has a slight dip in it, but as oil flows down, it will still drain just fine down into the pan as the weight of the draining oil pushes the oil through it. Gravity still draws it down. Just like your kitchen sink drain......
Old 06-15-2003, 04:10 PM
HXMan's Avatar
Looks good man ....but I would get a 45 deg fitting for the oil return off the turbo, and shorten up the line, you will have a much better drain path then.
Old 06-15-2003, 04:47 PM
shotty's Avatar
Default Re: My new turbo setup in my EF (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Looks good man ....but I would get a 45 deg fitting for the oil return off the turbo, and shorten up the line, you will have a much better drain path then. </TD></TR></TABLE>
It is a 45 degree......both off the turbo and off the pan
Old 06-15-2003, 05:03 PM
civperc's Avatar
bitchin', good luck with
Old 06-15-2003, 05:26 PM
New User
MikeExt's Avatar
Default Re: My new turbo setup in my EF (untensadude)
pics no work for me
Old 06-15-2003, 05:41 PM
G2turbo_terror's Avatar
Default Re: My new turbo setup in my EF (MikeCivette)
ack, I cant see anything...
Old 06-15-2003, 06:24 PM
shotty's Avatar
I reached my daily bandwidth limit already......
Old 06-15-2003, 07:13 PM
JDM92CX's Avatar
I can't see anything
Old 06-15-2003, 08:04 PM
RudeLude's Avatar
Default Re: (DroppedGSR)
looks good man, i mean awesome, i cant see the pics!
Old 06-15-2003, 08:15 PM
TeStUdO's Avatar
i cant see the pics either. pm me and ill host them for you
Old 06-15-2003, 08:31 PM
crashtest Sonny's Avatar
Default Re: (TeStUdO)
i wannna seeeeeeeeeeee
Old 06-16-2003, 05:59 AM
shotty's Avatar
Default Re: (4g_civic_si)
Well. I uploaded them to imagestation for the moment unitll I get a real host. SO if you wanna see them just go here.
http://www.imagestation.com/album/?id=4289914143
Old 06-19-2003, 02:25 PM
shotty's Avatar
Default Re: (shotty)
Old 06-19-2003, 07:42 PM
sporkcrx's Avatar
You ******* rule dude.
Old 06-20-2003, 10:55 AM
RuthlessEF-9's Avatar
Default Re: (sporkcrx)
Old 06-20-2003, 12:48 PM
91hatchcivic's Avatar
Default Re: (D16z6turbs)
haha we have like the same set up, 89 hatch, b16, but im waiting on my turbo set up ,any numbers on it?
Old 06-20-2003, 01:12 PM
SiRkid's Avatar
Default Re: (91hatchcivic)
thats sweet..its gonna haul ***!!!!
report back on spool time!
Old 06-20-2003, 01:20 PM
at the jetties fishin'
stackz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty &raquo;</TD></TR><TR><TD CLASS="quote">
Sure...why not? It has a slight dip in it, but as oil flows down, it will still drain just fine down into the pan as the weight of the draining oil pushes the oil through it. Gravity still draws it down. Just like your kitchen sink drain......</TD></TR></TABLE>
uhhh....because the stuff draining in your kitchen sink is water and not oil at 600 degrees haha
plus the 180 bend in the sink is designed to hold water so the sewage gases don't go past it and into the house and smell **** up.
as for your little "gravity pool" in the return line...oil at 600+ degrees tends to coke up over time as it cools off (even full synthetic oil)...and even worse so when run in high boost applications...
you honestly do need to get that low spot out of that line man.
Old 06-20-2003, 01:39 PM
PreIudeSI's Avatar
Location: California ... Beauuutiful, so cal, pwnited States
Default Re: My new turbo setup in my EF (stackz)
your oil return will work just fine, this is coming from experience, not just from behind a computer. Your setup looks nice, what manifold is that, looks like a full-race. lookin good!
-Michael
Quick Reply: My new turbo setup in my EF (lots-o-pics)
