My manifold to turbo bolts are loose....any way to tighten up without removing the whole manifold an
I have a 98 GS-R with drag 3...
Any suggestion, or am I gonna have to remove the wastegate, downpipe, manifold and turbo in order to tighten it up...
Also, when the car is off, and oil filled, if I take out the oil feed from the turbo, other than the amount of oil inside the hose, will the oil pressure still shoot up oil ?
thanks
stan
thanks
stan
Re: My manifold to turbo bolts are loose....any way to tighten up without removing the whole manifol
You might be able to tighten it is you a a "shorty" wrench with one ratcheting end for bolts.
Damon B.
12-14-2002 10:27 AM
