My fuel pressure is Low, what should it be around?
I have a d16y7 with a 19t and 12:1 fmu and missing link at 7lbs and it runs at about 30psi with the vacuum hose attached to my stock fpr with the bm gauge on the fuel filter? should i turn it to around 38psi with the vacuum on?
Re: My fuel pressure is Low, what should it be around? (Civiclx)
Um if your fuel pressure is at 30psi with a RRR while in boost, your running dangerously lean and Im sure it wont be long before your motor takes a dump on you. With a RRR is should be around 85-105psi while in boost depending on what disc you have in the RRR....
Blaze
Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">huh</TD></TR></TABLE> oh that was just a bump,lol
most people note their fuel pressure at idle with the vacuum line off. I think normal is around 42psi or at least that's what it is for a teg
4gencivicef9
11
08-19-2007 01:52 PM
