My engine bay does it look clean, what other cool stuff should i put in it? 56k beware
New User
I just got a digital camera so I took some pics, I am in the process of putting my project back together. I'm redoing the IC piping that's why there is an air filter
[Modified by EVOCELICA, 12:28 AM 12/4/2002]
Re: My engine bay does it look clean, what other cool stuff should i put in it? 56k beware (EVOCELIC
nice!! clean engine bay. hey are you driving the car around?? i read somewhere that if you dont have the compressor side hooked up, you can over rev the turbo??
New User
it's not my daily drive but yes i can drive it around, it runs stinky rich and builds no boost.
New User
I was thinking of selling it and getting a ITR valve cover
New User
so come on what cool stuff should i get?
ick...not feeling the valve cover...it you maybe coated it a flat black-- it would make it cleaner.
New User
yeah that's why i'm thinking ITR. I used the green one because the cover was cut
wat made you paint it green ? **** still looks good though
New User
i didn't paint it green, I had a crappy beat up b16 valve cover that was so tore up it looked like ****, so i traded it for a powdercoated lime green one, which i used because it had the cover cut so i could see the timing belt and cam gears
Looks clean... if you want to straighten it up some, hide some wiring, try to move some hosing around.
And if you get bored, start polishing stuff!
Another little thing to do is go to autozone, and check out the domestic performance aisle... they have the chrome snap on screw covers... they look nice.
New User
Just kidding
I rewrapped all the wiring with new electrical tape, and i rerouted and remounted most everything i could so it would look cleaner. I really can't move anymore hosing around, I got it best i can. I really have to think about what to do with the intercooler piping, the outlet from the turbo crosses over and right next to the manifold and dump tube so i wrapped it with heat wrap, but i'm worried that it's not enough. Also does anyone know where i can get the wastegate fittings one snapped and i want to replace it so i can use a EVC.
New User
see the broken fitting on the top of the WG
[Modified by EVOCELICA, 5:39 AM 12/4/2002]
i'm probably an idiot, but am i seeing things?
is that a turbo, BUT no charge pipes and an intake?
I was thinking the same thing. He has a wastegate, manifold, dp, etc...., but has an NA intake on the throttle body.
I was about to say the same thing how the hell are you going to have a manifold wastegate and turbo but have and intake pipe
New User
ha ha I was trying to start a new trend, no boost turbo hatch
Umn....How about a blue silicon vacuum hose kit to go with your blue plug wires.
i hope you dont drive it around like that, cuz it freaks over your turbo
Johnnydc
36
10-30-2009 09:02 PM
TuCKiNaLL4s
02-25-2005 11:12 AM
