My Dyno results...GSR/drag3 and AFC hack.
Old 10-23-2002, 06:50 PM
speedymon's Avatar
Default My Dyno results...GSR/drag3 and AFC hack.
268hp and 185ft/lbs
Link to the dyno video: http://www.dragva.com/vids/speedymondyno.mpg
96' GSR
DragIII kit @ 7lbs
440cc injectors and AFC hack.
Fuel correction
0-1k=-29%
2-3k=-40%
3-4k=-40%
4-5k=-35%
6-8k=-30%
Dont' ask me why i had -30% in the upper rpm. I was smoking alot on the run. Running real rich, and outside temps were around 60ish. Any comments good or bad?
[Modified by speedymon, 10:51 PM 10/23/2002]
[Modified by speedymon, 11:46 PM 10/23/2002]
[Modified by speedymon, 3:37 PM 10/25/2002]
Old 10-23-2002, 06:56 PM
CzanSOHC's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (speedymon)
No Cel at -30%????
keep it up!
Old 10-23-2002, 06:57 PM
speedymon's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (CzanSOHC)
Nope none. Strange when i look back at it. My CEL must have burnt out. Hmmmmm.
Old 10-23-2002, 07:11 PM
ZentraediEK's Avatar
Stock Block and Head?
Old 10-23-2002, 07:15 PM
PWRVTEC's Avatar
Come on now you did not post the video.....
I mean since I ripped it and all.......
Old 10-23-2002, 07:32 PM
New User
LshatchTurbo's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (PWRVTEC)
very nice numbers
Old 10-23-2002, 07:46 PM
HybridKOOP's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (lshatchturbo)
What confuses me most is...
Stock GS-R = 140whp give or take a few.
Boost = 1psi = 10hp give or take..
7 psi = 70hp or so...
140 + 70 = 210... you made 60 more than that.
Guess it all comes down to other factors, and tuning.
Old 10-23-2002, 07:53 PM
Phantom's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (HybridKOOP)
this is utter BS
Old 10-23-2002, 07:56 PM
POLLO's Avatar
Good numbers can't see the dyno graph too well but you still get a
Old 10-23-2002, 07:59 PM
Quick 200k Mile Motor's Avatar
dayum, also better than I thought @ 7psi.
I see sometingg. On your runs, did you gradually get into the throttle, or did you stomp on it?
Old 10-23-2002, 08:12 PM
Trigun's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (Quick 200k Mile Motor)
damn those are some really good numbers for 7psi. when i dyno tuned my car @ 6.5psi, i hit only 227/167 with hondata .. i doubt an extra half pound of boost would net me 30+ hp.
Old 10-23-2002, 08:23 PM
zojirushi's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (Trigun)
damn, thats awesome!
i wanna get mine dynoed now... maybe some 550 injectors
Old 10-23-2002, 08:29 PM
SiRkid's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (zojirushi)
nice
Old 10-23-2002, 08:35 PM
filetofit
Guest
Posts: n/a
Normal atmospheric pressure is 15 psi and 2.9 volts on the MAP sensor. 7 psi of boost corresponds to (2.9/15) x 22 = 4.25 volts which is then scaled down by 30%
4.25 volts x 0.7 = 2.98 volts. The ECU wont throw a CEL until about 3.1 volts
Did you use any timing retard, either at the distributor or with a BTM?
New User
VaporTrail's Avatar
just remember, the AFC hack may work for fueling, but does nothing for ignition timing. I'm still not sold on it, at WOT its running a lot of ignition timing, probably more than you are running, though your HP numbers are a bit low, your torque is right there.
Old 10-23-2002, 10:18 PM
TurboCRVTEC's Avatar
wow. thats a beast.
sorry to get off topic a bit, but should I expect these kind of numbers with my
turbo b20/vtec? all custom kit but really the only diff. thing is i'll use a strait t3 turbo.
Old 10-24-2002, 12:31 AM
New User
blkDOHCsol's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (TurboCRVTEC)
****** sweet
Old 10-24-2002, 05:12 AM
speedymon's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (blkDOHCsol)
Ignition is not retarded. on me, yeah i know. I'm in Hampton Va so i think i'm at sea level. I also have a 3" exhaust from the 2.5" DP back. No cat, 2 dynomax mufflers. Yeah the guy that was doing the dyno stomped on it. Any advise on getting the lower torque up, or is that due to spool up?
Old 10-24-2002, 07:05 AM
LEON's Avatar
I'ld like to see the A/F ratio graph!?!? Got one?
Old 10-24-2002, 07:14 AM
dwilson's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (LEON)
me to
Old 10-24-2002, 07:37 AM
bgod's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (dwilson)
i must be dumb or something.
great numbers but i'm just not understanding that dyno plot.
where is your torque plot? it seems to read 250+lbs.tq. at 7.5krpm's.
do you have a better dyno plot so we can analyze.
Old 10-24-2002, 07:52 AM
FredoSP's Avatar
looks good to me!!
Old 10-24-2002, 01:53 PM
speedymon's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (FredoSP)
My ricer friend is gonna take a pic of the dyno sheet. Then you guys can get a better look at the graph.
In case you didn't see it the link to the video is on the first post. Engine is totally stock.
[Modified by speedymon, 5:54 PM 10/24/2002]
Old 10-24-2002, 01:57 PM
TeStUdO's Avatar
nice, i cant wait to get my GSR/drag3 v-afc hack dynoed
Old 10-24-2002, 02:13 PM
khang77642's Avatar
Default Re: My Dyno results...GSR/drag3 and AFC hack. (00si5)
nice numbers
Quick Reply: My Dyno results...GSR/drag3 and AFC hack.
