My day of boost has finally come
Yes, my motor just got back from a local machinist, and holy **** does it look good. I have a stock bore b16a w/ Darton sleeves, JE 9.2:1 comp flat tops <utilize 1/4in longer wrist pin>, Westwood wrist pins, Crower rods, balanced and blueprinted crank, Prodrive oil pump gear, and ARP studs. I had all the sharp edged on my pistons rounded so there are essentially no hot spots. It has taken me forever to get this **** together and get it finished, but it finally has. In three weeks the motor will go in along with my Quaife and Clutchnet 6-puk to begin the break-in process, then it is time for the boost. I have a 60 trim to4e <.63A/R>, AEM EMS, and other gobbily ****. I only have 550cc RC's and I need some bigger ones, but other than that I am ready to roll. Thanks to all of you that helped with my decision making a year or so ago, and for all the other help you may have provided. Just wanted you to have the update on this. Thanks again guys!
Re: My day of boost has finally come (Boosted Ego)
How much do you plan on boosting? I think 550's should be fine unless your going all out with some crazy #'s. Can the ems support additional injectors?
Re: My day of boost has finally come (civicudesire)
On that setup you are definately going to want bigger injectors.
I just dynoed my car with 550's and i tapped them out on my car @307Whp and 235Wtq.
I am going to but 720's as should you.
Nice setup bro!!
Brian
Nice setup bro!!
Brian
Re: My day of boost has finally come (prophet)
Yea, the EMS has the capability to control secondaries, but **** I might as well go with some 720's. I really want to get in the neighborhood of 400whp, which I think is really feasible.
Hey, if you need someone to take the 550's off your hands, IM me
SOunds like a damn nice setup man!
to doing it right the first time
Re: My day of boost has finally come (ill_take_one)
how much did the pro drive oil pump gear run you? Just curious I would like to invest in one.
good luck on the car sounds like its sick!!
VTC_CiViC
12-07-2001 11:15 AM
