My D16Z6 turbo SOHC build (with pictures)
So this year I decided to do a bit of a build for my SOHC. Last year I ran a stock z6 with boost, and the previous year a d15 with boost.
This setup will consist of a stock sleeved D16z6 with Arias 9:1 75.5mm pistons and eagle H-beam rods.
Progress may be a little slow since Im not rushing but Ill post updates as they come.
This week I got the block and head back from the machine shop. The block was bore/honed .020 over. The head was torn down, valve guide bushings replaced, new seals, 3 angle valve job, and surface machined for a perfect seal. It was also bead blasted and has been port and polished.
Yesterday I threw a quick spray of high temp aluminum paint on the block.
Here you can see the freshly honed finish. The hone was done slightly smoother than some to allow for longer ring life. This means my rings will take slightly longer to seal properly though.
Here you can see the notches needed to clear the eagle rods.
The piston and rod combo. (sorry its a little out of focus, quick snap)
The freshly machined head. Looks so clean it almost seems like a shame to put it on.
The old bearings/rods/pistons that I pulled out. I kept them all in order just in case. (couple bearings still in the block for attaching to the hone machine)
Oh and of course, this build powered by heineken.
Thats it for now.
Thats it for now.
Re: My D16Z6 turbo SOHC build (OrangeBoost)
lookin good I'm gonna start a thread on my d series build this year as soon as it starts going together. I built one last year but I spun a bearing so I'm at it again.
Re: (OrangeBoost)
The build I did last year was the first for me too....heres a link to it. Dunno if anything will help out at all but if you got any ?'s let me know. Good luck!
https://honda-tech.com/zero...age=1
wrenchin'
1 Post
Re: (G3NR8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 »</TD></TR><TR><TD CLASS="quote">I built one last year but I spun a bearing so I'm at it again. </TD></TR></TABLE>
yeah 9500 rpm on a stock y8 oil pump will do that to ya!! now you have a z6. NO MORE OILING ISSUES!
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">yeah 9500 rpm on a stock y8 oil pump will do that to ya!! now you have a z6. NO MORE OILING ISSUES!</TD></TR></TABLE>
umm... all the d-series pumps are the same. And they all suck equally.
I wish we could fit B pumps on our motors; that would solve a lot of problems.
Re: (Pay2play killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa »</TD></TR><TR><TD CLASS="quote">
umm... all the d-series pumps are the same.</TD></TR></TABLE>
No. They y8 was made poorly and can't pump out much oil at high rpm thus leading to oil starvation and bang there goes a rod.
Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">No. They y8 was made poorly and can't pump out much oil at high rpm thus leading to oil starvation and bang there goes a rod.</TD></TR></TABLE>
thats what happened to me
building a z6 block with a y8 head this time....
Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost »</TD></TR><TR><TD CLASS="quote">One more pic. I like it because you can see the machining detail on the piston, especially the valve relief. Note the sticker in the background.
That piston just looks like it has hotspots waiting to happen :-/
Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost »</TD></TR><TR><TD CLASS="quote">On the sharp edges you mean?
Ive already rounded the edges on one of them. Ill get around to the others eventually.
Any recommendations?</TD></TR></TABLE>
More like the piston design. Its just got such low recesses and is dimpled for them all the way to the outside of the piston. I just dont "like" it really... no real tech info to back me up . I got outta my engineering program years ago... and its all faded.
Its partially with how it its physically less material between the top ringland and that recessed area. Allowing less material to hold/disperse heat at that point.
Shrug, its just opinion.
Re: (EK k kay)
really; i looked at my d16a6 and d16z6 pumps closely and internally they looked identical; and i looked at a y8 pump but didnt take it apart and they all looked very similar to identical.
Re: (Blanket Jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blanket Jackson »</TD></TR><TR><TD CLASS="quote">Good luck with the build. Keep us updated.
What intake mani you going to run?? Sorry, I didn't read if you had said that or not.</TD></TR></TABLE>
Im going to be running the z6 intake manifold.
minor update: just got finished rounding the edges of the valve reliefs a bit
Re: (AJxr)
Jordan it's looking like your making some good progress on the build .Can't wait to see it in springtime,there should be a few heavy hitting D-series Turbo's this summer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost »</TD></TR><TR><TD CLASS="quote">Here you can see the freshly honed finish. The hone was done slightly smoother than some to allow for longer ring life. This means my rings will take slightly longer to seal properly though.</TD></TR></TABLE>
Actually, the purpose of the coarseness to the hone is to allow deeper pockets for the oil to reside in. A smoother hone will = less oil on the cylinder walls and thus QUICKER ring wear.
Remember, the pitch and the coarseness to a hone are critical. The pitch cannot be too steep, or the oil will run back into the pan. Too flat, and you have too much oil on the cylinder walls and the oil control rings cannot keep up. At this point, you burn oil. The same idea when it comes to the grit used on the hone. Too smooth will allow shallower grooves for oil retention... Too coarse and you start gobbling up rings as you grind them past the valleys.
