my car doesnt boost in 1st no more! help asap!!!!
yea.....just like 2 days ago, my turbo setup on my crx was working just fine. now yesterday and today, it just feels like it doesnt pull anymore in 1st gear. before i use to hit boost in 1st gear....now all of a sudden i cant even reach 0 psi in 1st.....i took off all my piping, and retightened everything, i dont see any leaks in my piping or anywhere. i checked all my vacumm lines and they are all fine also...... what the hell is wrong?????? when i rev in neutral it spools and everything, but it doesnt read any boost when i rev in neutra. before i use to read boost, or at least hit 0 psi......
help me!
john
help me!
john
Re: my car doesnt boost in 1st no more! help asap!!!! (SloCrX)
Does it go away after 1st gear or is it still screwed up after first?(will boost, but takes alot longer)? If your car seems like it something that is not going away after first, there is a huge possiblity that you are missing a fire in a cylinder. check your connections (plugs, wires, cap, and rotor, good luck
Re: my car doesnt boost in 1st no more! help asap!!!! (CivicSoul)
its is most likely your exhaust manifold gasket or the gasker that connects the turbo to the manifold. hope that helps good luck.
stunnerone23
09-01-2008 03:34 PM
