My B18C1 Engine Build/Assembly
Old 04-19-2012, 08:25 PM
  #1976
Moderator
TheShodan's Avatar
Default Re: My B18C1 Engine Build/Assembly
Originally Posted by CaliforniaDad
Yeah I was into drift racing at the time. It's a Drift style. Comes from Japan, They mirror the decals so that when another driver it looking in his side or rear-view mirrors it appears to him as a normal image "not backwards" Ever notice that on some ambulance the word "ambulance" is spelled backwards on the front of there car so that when you look in your rear-view mirror it will read normal to you?
It was even before Drifter style. I was seeing these back on cars in 1999 in both Japan and Australia
Old 04-19-2012, 11:28 PM
  #1977
rich7777's Avatar
That car is a PURE work of art Californiadad.
Old 04-20-2012, 12:19 AM
  #1978
No-Traction = Fun
CaliforniaDad's Avatar
yeah and that was back in 2004.
Old 04-20-2012, 01:29 AM
  #1979
slowtegkauai's Avatar
That sounds more like it! haha damn you really worked that G. The only thing I did to my car was suspention parts. Was the motor internally stock? and drive train?
Old 04-20-2012, 04:27 PM
  #1980
No-Traction = Fun
So about my brakes, I got a call and was told the Hawk rotors are on back order for a few weeks so I decided to just run with some Power Stop rotors "Slotted Only" front and rear and have decided to go with the Hawk HPS brake pads front and rear, As I'm afraid the HP plus pads would be too aggressive for daily driving.
Old 04-20-2012, 04:41 PM
  #1981
Moderator
TheShodan's Avatar
You'll go through those pretty fast. Those are mainly used for just outside OEM.. They'll only provide about 60% of the stopping power you need.
Hell, even my wife goes through HPS's on our Family TSX. They're ok.. but definitely not for turbo. Which is why I recommended what I did originally.
I get NA guys who go through HPS's very quickly on the street and perform about 1/4 of the acceleration as you do. That's why I stated the HP+ pads. The higher level ones over HP+ are for circuit only.
Also, NAPA blanks would have been preferred, as the Power slots warp very easily. When I was a distributor for Power Slot, that was a design flaw they never truly fixed...
Old 04-20-2012, 05:10 PM
  #1982
No-Traction = Fun
What about HP Plus for the front and HPS for the rear since the front does most of the braking?
So the power slot rotors warp easy? So your telling my just plain old napa 23.00 blank rotors are going to be better?
Napa premium fronts
http://www.napaonline.com/Catalog/Ca...+50001+2001002
Napa premium rears
Old 04-20-2012, 05:26 PM
  #1983
Moderator
TheShodan's Avatar
Napa premium fronts
Napa premium rears
The NAPA premium fronts are what you want to use instead of the Powerslot.
You can use the HP+ for the front and HPS for the rear. Yes. That would be acceptable.
The Premiums are like $58.00 instead of $23.00 and are resurfaceable.
Old 04-20-2012, 05:27 PM
  #1984
No-Traction = Fun
What about the Autozone rotors?
Old 04-20-2012, 05:45 PM
  #1985
Moderator
TheShodan's Avatar
I remember your video..... you should know by now ANYTHING Autozone is worthless.
Napa uses a different private label distributor than Autozone. Napa uses a company called A1, while Autozone uses another company that just was horrible (the name escapes me now)
Stick with Napa specifically, please
Old 04-20-2012, 05:57 PM
  #1986
No-Traction = Fun
Yeah I hear ya. So will the HP Plus pads be noisy?
Old 04-20-2012, 05:59 PM
  #1987
Moderator
TheShodan's Avatar
Not really. but you can't stop without some metal in the pad. But won't sound like a track pad, if that's what you're worried about.
Old 04-20-2012, 06:01 PM
  #1988
Turbo-LS's Avatar
Or some brembo rotors. I've had a lot of luck with mine.
Old 04-20-2012, 06:46 PM
  #1989
No-Traction = Fun
brembo blank rotors right?
Old 04-20-2012, 06:54 PM
  #1990
Moderator
TheShodan's Avatar
Yes. blanks.
Old 04-20-2012, 07:01 PM
  #1991
Turbo-LS's Avatar
Yes blanks but I have drilled slotted and they've been good to me. Went through whole set of p,ads and rotors still inspec and not warped
Old 04-20-2012, 07:05 PM
  #1992
No-Traction = Fun
I found the complete set of Brembo Blanks for the 94-01 integra GSR for 162.50 shipped to me. Good??? But, am I really going to notice a difference between the brembo blanks VS the Napa premium blanks?
Old 04-20-2012, 07:07 PM
  #1993
Turbo-LS's Avatar
40 bucks a rotor sounds good to me
Old 04-20-2012, 07:12 PM
  #1994
Moderator
TheShodan's Avatar
Its one part of a whole system Dave. "feeling the difference" is not going to be in a rotor. Its the combination of parts and their durability that separate the weak from the flock.
If you want to use Brembo blanks, fine. those work as well, as long as they weren't the Autozone. The difference is now up to the HP+ pads and brake fluid that I recommended: No Super Blue, No ATL or Castrol.. This, and this only due to its high dry boiling point of over 500*
You need 3 bottles:
http://www.amazon.com/Motul-RBF-Raci.../dp/B000AURZ08
Old 04-20-2012, 07:16 PM
  #1995
Turbo-LS's Avatar
Racing brake fluid helps.
Old 04-20-2012, 07:23 PM
  #1996
No-Traction = Fun
Oh Jesus....when does it stop!!! You like spending my money! Don't you MAC!
So something like this --> http://www.ebay.com/itm/Motul-3-RBF-...#ht_617wt_1163
Old 04-20-2012, 07:57 PM
  #1997
Moderator
TheShodan's Avatar
the link I supplied you has it for $55 for 3 bottles shipped, and not $65... I can't STAND eBay.
I bought a couple bottles myself this week, actually.
Old 04-20-2012, 08:03 PM
  #1998
Moderator
TheShodan's Avatar
If I want to come home in one piece to see my wife and daughter after being in my car chasing a bike, you damn right I will.... especially for this. Remember, I'm a dad, too.
Instead of a chasing down bikes with a Surfer, I'm using this: TR3030R
Old 04-20-2012, 08:08 PM
  #1999
chi_gsr's Avatar
Brembo blanks with HP Plus I can tell you are very nice and the stopping power is just great, driving to work i have some spots on the highway where its stop and go and or people cutting me off where i need the stopping power otherwise i will hit someone. Belowis the price i paid just change the front rotor and pads to your gsr vs mine civic and you should be in the same ball park. Break dust for me is minimal and i brake alot no noise what so ever just my 2 cents
Thanks for the inquiry. We've got all these parts in-stock. Here is the quote:
$34 each x2 - Front Brembo OE Brake Rotor
http://www.importrp.com/product.php?productid=111090
$28 each x2 - Rear Brembo OE Brake Rotor
http://www.importrp.com/product.php?productid=116029
$70.14 - Front Hawk HP PLUS Brake Pad Set
http://www.importrp.com/product.php?productid=248120
$56.96 - Rear Hawk HP PLUS Brake Pad Set
http://www.importrp.com/product.php?productid=277523
Total = $251.10 with Free UPS Ground shipping
Old 04-20-2012, 08:26 PM
  #2000
No-Traction = Fun
Thanks brother. I plugged my car in and I can get all 4 brembo rotors shipped for 122.00 thats a steal!!
Quick Reply: My B18C1 Engine Build/Assembly
