My B18C1 Engine Build/Assembly
#677
Re: My B18C1 Engine Build/Assembly
CaliforniaDad, are you keeping all your pistons or are you going to get a new single piston? Glad youre getting it rebuilt and shooting for more power!
And rich7777 heres the single post where he breaks it down, its a long thread with tons of different people throwing out opinions.
http://www.tamparacing.com/forums/mi...ml#post8701162
#678
No-Traction = Fun
Yeah I'm keeping all my pistons they are fine. Just going to order new rings. We plan on bumping the compression a little by taking a lil off the block and head. So I should be right about 8:9.1
#679
No-Traction = Fun
Does anyone have a turbo boot in black 2.75" to 2.5" I need one that goes from my intake to turbo inlet. Also need a black silicone upper radiator hose. 97 Integra GSR
#682
No-Traction = Fun
.........Update..........
Today I was stripping apart the head. When I removed the fuel rail and inspected the injectors, I found that there was debries in top of injector #3 Looks like some black plastic bits. This could be what caused the problem with cyl #3. It must have been causing a lean condition for that cylinder.
#688
Moderator
It's kind of pricey. Both the backplate, and housing would have to be replaced, plus the wheel, PLUS the machining. There is a GT3540S upgrade that's less expensive, in which I can keep the same backplate and bore out the housing a bit better, for 65lbs/min, instead of the 59lbs/min you currently have.
#689
AllShowNoGo, Thank you for that link It was a nice read.
CaliforniaDad, Thats a pain about that injector, maybe if you took them out to be flow tested and cleaned this wouldnt of happened . Never mind anyway... By the looks of things now you seem like your glad it broke LMAO.
#690
No-Traction = Fun
#691
#694
Are you running aftermarker valves, springs and retainers in this ? You have ITR cams don't you ? Sorry, i know i should search...
#699
No-Traction = Fun
Ou yeah I'm sure of it! I took the fuel filter off and it is deff the filter coming apart! I went and bought an AEM highflow filter to replace it. And some new 850cc high impedance injectors.
