The Most Horsepower
The Most Horsepower
I wanna know cause I keep getting so many different answers, and I know I will keep getting different answers. But I need to know if I do all the internals(bullet proofing the engine pistons, rods, etc, etc.) Upgrade the fuel system what's the max horsepower I can see out of a D16Y8(SOHC VTEC). My goal is to make 300hp to the wheels. Please someone tell me if this is possible. I keep hearing from friends swap the engine get a B16a2 SiRII some say turbocharge this engine, I'm stuck if I can see 300hp I'll turbocharge this engine if not then I'll go with the B16(keep in mind I don't want any Acura Integra engine) I have a Civic and if I swap I'm going to stay Civic so although I know of the B18C1 and C5 I'm not interested, neither am I interested in either of the H22's or the B20 or the Civic Type R(just too damn expensive) for that matter.
Re: The Most Horsepower (Project_SOHC_EX)
Hah, good luck man...........keep us posted on what it costs....
Re: The Most Horsepower (93LSivic)
i think it is possible, but only under good tuning!!! the people at fmax got a stock bottom end sohc up to 225hp so why not 300!! 300 is my goal with out a sleved block.
http://www.f-max.com/D16A%20VTEC%20DYNO.htm
Re: The Most Horsepower (ATurboCivic2NV)
save ur money and swap in a b18b. they can be had for really cheap. acura honda same ****. you will actually save money swapping in a b18b and turboing it opposed to doing the same with the d16.
Re: The Most Horsepower (88CRXHybrid)
I'm building a 350+whp D16 which will cost me less or very close to a complete B18C5 swap.
$4k for the complete motor and head + tuning
$1k for the Hondata 2B
$1k in turbo upgrades from what I already have
So *roughly* $6k, which is about what a B18C5 swap goes for +/- $500
BTW a B18B/B20/B18C1 will come up ALOT cheaper than this!
If money isnt a factor then 300whp is very possible on the d16. Get yourself a built block with a ported head and a kick *** fuel system, and a standalone and your set, with other misc. items such as a good ignition system. However you could get more then 300 whp from a dohc. If you decided to go Dohc it would be a better starting ground. If you do as I stated above on a dohc you could easily get over 400whp.
P.S. No disrespect to the sohc people.
Foust1979
10-22-2018 06:54 PM
Silkex
11
01-19-2011 07:30 AM
