This mitsubishi turbo, any info on it?
I just picked up a free mitsubishi turbo and wastegate. 1997 eclipse, says Td05h on the compressor housing.
Decent turbo for daily driving>? WHast the psi that car is set at stock?
Re: This mitsubishi turbo, any info on it? (Diyracing2)
Looks like its a decent one. Capable of 340hp at 15psi.
What is the stock wastegate on that set at???
Any mods i should make to this turbo?
I use this turbo on my SOHC and got 200hp with a 8psi gate, and still rockin it. DOHC I would not use this small turbo because it will run out in 3rd gear.
Re: This mitsubishi turbo, any info on it? (SOHCmaster)
alright. think i will sell it then and get a bigger one...
It says its capable of 350 hp out of this turbo.... Did you just remove the wastegate and block it off and use external gate?
STOCK turbo off of a 97 DSM? If it's a t25, it's no where near capable of 350.
What does it look like? Left one. Or right one?
Re: This mitsubishi turbo, any info on it? (Finest)
its the one on the right, It sayus TD05h right on there in the pic. thats the one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 »</TD></TR><TR><TD CLASS="quote">its the one on the right, It sayus TD05h right on there in the pic. thats the one...</TD></TR></TABLE>
Count the compressor blades, like the way in the picture. Do they overlap, or are a single blade?
A 14b is capable of around 280ish. A 16g would be able to flow close to 350's. And the evo3 Big 16g is close to 400's. But they all look the same from the outside, even with the TD05H markings.
if its a stock turbo off a 97 its a t25 like stated before. a decent turbo for a small setup, but id sell it money can be better spent.
Landon
Landon
Re: This mitsubishi turbo, any info on it? (boosted_dc2)
How can you tell its a t25. Did a search on google and everywhere it says its the 14g. Dont know what the hell that means. ahah
T25 is made by garrett. Its the one pictured on the left. A TD05 is made my Mitsubishi. If it has dual blades its likley a small or big 16g. if it has single blades its a 14b.
I would be suprised if it was a 14g, while that wheel does exsist.... it's really rare to actually see it on anything.
Is the turbo watercooled??? If no it's possible it could be an 18g. Many people went that route due to the fact you could get the dry housing unit for like 439 new.
Re: This mitsubishi turbo, any info on it? (GimpyAccord)
Yes its watercooled...
Twin bladed badness. ahaha its so tiny compared to everyones turbos on here but its new and its damn free.. And EVERYWHERE says you can get 350 out of it.. I dont need 350... 250 to the wheels would tickle my pink.
Remember that DSM's run significantly higher (than your typical DIY Honda) boost pressures to accomplish 350-400whp on those
But for 250, you should be good to go.
Re: This mitsubishi turbo, any info on it? (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan »</TD></TR><TR><TD CLASS="quote">T25 is made by garrett. Its the one pictured on the left. A TD05 is made my Mitsubishi. If it has dual blades its likley a small or big 16g. if it has single blades its a 14b.</TD></TR></TABLE>
Exactly.
Exactly.
ExVtec
06-04-2004 01:25 PM
