Missing a part for GREDDY OIL BLOCK ADAPTER?
I just received my Greddy Oil Block Adapter today and I haven't actually tried installing it on my car yet but while putting it together...i noticed that when I screw the two fittings together...they dont hold tight against the whole adapter (the adapter can back and forth about 2/16in between the two fittings and spin...is it supposed to be like that? It seems like there is supposed to be a washer or something??? somebody please enlighten me!!
thanks in advance!
thanks in advance!
Re: Missing a part for GREDDY OIL BLOCK ADAPTER? (teameracer3)
Those two fittings you're talking about, you're only going to use one of them. They include 2 to accomodate different sizes of oil filter applications. Pick up a new honda Oil filter and see which one screws in tight, that will be the one you use. Then place the adapter on the block (O-ring gasket facing the block) and then screw that fitting into the center, and that will hold the adapter (sandwich it) to the block. Got it? yeah the adapter can spin, but once you tighten it all down on the block, it doesn't spin anymore. Screw on your filter and your done. (I put on a lil bit of teflon on the 1/8" plugs for a better seal as well)
