Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Missing Link fix retarded boost problem? (https://honda-tech.com/forums/forced-induction-16/missing-link-fix-retarded-boost-problem-861333/)
spark plugs. May 11, 2004 06:49 AM
When i start boosting, the car throws on a check engine light and starts acting all hurt. It bogs, it runs rich, and the exhaust sounds 20349832 louder. From using the SEARCH feature (yes, i already used it) i'm beginning to deduce that it's the stock map sensor reading boost. if i get a 'missing link' from synapse, would this remedy the problem?
spark plugs. May 11, 2004 07:16 AM
Re: Missing Link fix retarded boost problem? (troublecodes)
bump
eLusive Acclude May 11, 2004 08:16 AM
yes it should your ecu doesnt like tos ee bost therefore putting the car into limp mdoe hence the bogging and lodu exhuast noise etc. you can also use scuba diving check valves isntead of a missing link
spark plugs. May 11, 2004 08:30 AM
Re: Missing Link fix retarded boost problem? (eLusive Acclude)
thanks man! https://honda-tech.com/forums/images/smilies/emthup.gif
eLusive Acclude May 11, 2004 09:06 AM
your welcome ^_^
