Mini-me Garret turbo problem runs really wierd plz help !!
Okay so I had everything in injectors, chipped P28 from phearable, fuel pump and everything else... I drives perfectly fine. The problem I noticed was that when I pull it to 4k rpm and shift to 2nd gear and I was there at 4k rpm shifted to 3rd there at 4krpm it sounds like I'm just reving the car instead of pulling it. Does anyone know what this problem could be? Because if I don't full thorttle it'l be normal, but when I do it sounds like my gears after first are just reving and not going anywhere.... Please help
Re: Mini-me Garret turbo problem runs really wierd plz help !!
what do you think I should do? bleed the clutch over first or take the tranny out and check everything in there? It's a brand new oem clutch I dont think anything is wrong the the clutch but it could be installed incorrectly.
id check everything having to do with the clutch and let pulling the tranny be your last resort
my .02 cents
my .02 cents
sxecustoms
12-23-2003 06:05 AM
