MBC valve... WILL THIS WORK?
i have a valve that basically just controls flow by turning a *** (as you screw the *** in, the hole gets smaller. so basically it will just restrict some of the air flow in the vacuum line running to the wastegate.
will this work as a manual boost controller?
Re: MBC valve... WILL THIS WORK? (superstud)
I think that you will find your device will just slow the wastegate response. Once it's open, it will be at the spring pressure.
danmej1
01-11-2010 08:28 AM
Sinner
07-28-2004 08:20 AM
