MBC on dual wastegates
Old 04-27-2009, 03:05 AM
a1320honda's Avatar
Default MBC on dual wastegates
I did some looking around and couldnt come up with a stright answer. Can you run a manual boost controller on a dual wastegated setup? Ive tried 2 different controllers and no matter what i do, it goes straight over whatever im tryin to run. I set a boost cut at 20 but tryin to run about 18. No matter what i do it just tries to go straight over 20psi. Ive heard you cant just throw a MBC in the same way with a single gate. Ive got an AFI top mount, dual 44 tial gates, but the turbo is not twin scroll. Any help is greatly appreciated.
Old 04-27-2009, 05:41 AM
official honda whore
EARLdaSQUIRREL's Avatar
Default Re: MBC on dual wastegates
do you have it split to the 2 gates, or just to 1 gate
run a t off from the mbc to both gates
why not go ebc via mac/aem/hondata solenoid anyways
Old 04-27-2009, 10:38 AM
a1320honda's Avatar
Yeah its T'd in right. And I've tried just about every way of hooking it up with the same reults. I'm on Crome right now, gonna switch to eCtune and do the EBC but that's not gonna be for a couple months. I do have the other springs to put in the gates to make it 20psi, but I'd just like to know that a mbc won't work.
Old 04-27-2009, 02:24 PM
4drhoar's Avatar
is the mbc hooked up backwards?
Old 04-28-2009, 09:57 AM
a1320honda's Avatar
Yeah ive tried everything to make them work right. Ive bench tested both MBC's and both test fine so i dont know. Ive heard that getting them to work on a dual gate setup is impossible, just wondering why?
Old 04-28-2009, 10:11 AM
dart2.2's Avatar
i had no problems with my hallman holding 34 psi on my dual 44mm tial gates. i just hookrd it up according to the instructions and tee'd the lines.good luck man.
Old 04-28-2009, 10:58 AM
HiProfile's Avatar
Higher boost is less of an issue to control, since the WG's open less. One thing it could be is lack of flow. You may need 2 MBC's because the rising boost can't flow through the single MBC enough to fill both WG's. If they can't, you will spike quite a bit until the WG opens the valve enough.
I'm assuming that with just spring pressure, you can maintain LESS than 18PSI?
Old 04-29-2009, 05:30 PM
dart2.2's Avatar
when my car was tuned we started off the gates, 10psi and moved up from there. no problems running 10 psi with the s372.
Old 04-29-2009, 06:03 PM
a1320honda's Avatar
Yeah i got frustrated and ended up putting another set of spring in em to get to 21ish psi. thanks for all the help.
superhatchbackbros
06-30-2007 09:17 AM
ej8dude
03-06-2007 10:19 PM
ATS*Mark
02-02-2004 04:22 PM
slooogsr
10-26-2003 01:36 PM
Aeka GSR
04-09-2002 07:49 AM
Quick Reply: MBC on dual wastegates
