Max HP from stock ITR fuel pump?
What is the flow rate for the stock ITR fuel pump? How many HP will it support? I know that with larger injectors I won't need as much fuel PRESSURE, but I will still need to more fuel VOLUME to increase HP. Does anyone know its limit? I have a jrsc so even if I go to the max (10-11 psi) I'll still be well under 300 whp.
Re: Max HP from stock ITR fuel pump? (fredtoast)
id swap it out for peace of mind , i went like 240 ish already with it already but swapped out for Walbro for peace of mind .
