Max HP on B-series springs?
Re: Max HP on B-series springs? (BrooksGSR)
if your on stock cams with those stock springs and retainers, they can hold pretty much anything hp you throw at them. Ive never heard of them failing from high HP...only high revving, and larger cams on stock springs.
Re: Max HP on B-series springs? (J337_UNIT)
Thanks, yea the motor wont see over 8000rpms so i hope they will be ok, it will only see high boost any one else???
i believe springs and retainers are only suseptable to high revving and non OEM cams. Even if you did make crazy HP you're on a stock head so you can only do so much with that. high boost won't do anything to your valves
boostin4door
03-09-2005 09:41 AM
SPOONfdEK
01-11-2004 07:20 PM
Ri5e
07-19-2002 10:38 AM
