Master Power Turbo??? any good?
So any feed back on these? Looking into using one t3/t4 50 trimm..... Are they any good? I heard thats what they run out in brazil
Moderator
Re: Master Power Turbo??? any good?
The true "Master Power" from Brasil is actually a good turbo, but the "e-bay gods" took the name and ruined it by selling their cheap garbage. So that you won't get the crap, chances are you aren't going to get the real Master Power, so stay away
Well the guy I'm buying it from was the one who told me its from brazil here is a pic, how do I know if its the one from brazil or ebay one? And the shodan, on my other thread you said I needed a t3/t04e .50 ar. The guy said this is a t3/t4 .50 ar. Is that the same thing?
Thanks for help
Thanks for help
Thanks for help
Thanks for help
Moderator
The shodan this is the only pic I have of the turbo, is that sufficient enough?
I also have what the plate says on the turbo
right column:
N* De Parte
810025
Serie
06C258944
Model
S 50
right column:
N* De Parte
810025
Serie
06C258944
Model
S 50
ok so I went on the master power website and I found the part number. It says the trim is a 48. Is that going to be close enough to a 50 trim? what does that mean? I will make less power? spool slower??
here are the specs off the website. The shodan will this work for my build? stock b16 with walbro, golden eagle fuel rail, aero or aem fpr, and still deciding on size injectors?
ive heard that spa turbo is now masterpower, its straight out of brazil, ive run one and had good experiences, actually trying to get rid of my 57mm inducer one cuz i want more power, but good spool, doesnt leak or smoke, seems to be a decent turbo.
at www.brucespeed.com you can find them, theyre supposedly the same as masterpower.
wilham320
05-30-2008 01:02 PM
