Map Sensor? Please help!!
I was just wondering if I ordered a 4 bar map sensor from hondata or omni, if it would mess with my street tune or if it would be able to go ahead and install it?
Thanks ahead of time to anyone who helps out with the ? !!! |
I would think as long as your fuel management is okay with it, you will be fine. The sensor itself wont change your tune, just has the capability of reading higher pressure.
Re: (Civicman86)
You should absolutely monitor things with a wideband after changing map sensors. Remember, your map sensor is one of the most important sensors on your car.
Re: (nowtype)
well right now i have s100 with boost option on a street tune on 7 psi.... so basically i guess my question would be would youdo it!?
Re: (weziebme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weziebme »</TD></TR><TR><TD CLASS="quote">well right now i have s100 with boost option on a street tune on 7 psi.... so basically i guess my question would be would youdo it!?</TD></TR></TABLE>
no, at least not without consulting my tuner first. |
Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
no, at least not without consulting my tuner first.</TD></TR></TABLE> okay thanks https://honda-tech.com/forums/images/smilies/emthup.gif |
| All times are GMT -8. The time now is 05:49 AM. |
