Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Manual Boost Controller gone bad ??! (https://honda-tech.com/forums/forced-induction-16/manual-boost-controller-gone-bad-2960475/)
pcguy760 Jul 21, 2011 12:29 PM
For some odd reason, my Hallman ES mbc suddenly stopped adjusting. For example, I got a 10 psi WG spring and with the Hallman hooked up, I cannot get more than 9 psi of boost with the Hallman mbc fully close, etc. Do these actually go bad suddenly?
I know its not the WG cos I put a 15 psi spring and it went to 13 (with hallman mbc in line)
I just do not understand how these go bad??? ....
viper_boy403 Jul 21, 2011 06:55 PM
Re: Manual Boost Controller gone bad ??!
take it apart and see if something got messed up or stuck etc. Theyre just a ball and spring, nothing complicated
pcguy760 Jul 22, 2011 11:18 PM
I took it apart and nothing was stuck, etc. buuuuut it made sense why my tuner said the spring in it felt very soft for some reason... the spring looked like it had some sort of corrosion on it so I dunno whats the case with it but its certainly done for...
civickiller Jul 23, 2011 05:50 AM
spray it clean with some brake clean then try it
pcguy760 Jul 23, 2011 03:50 PM
Yep tried cleaning it etc. etc. Hallman emailed me and said it might be the spring needs to be changed to higher tension (???) which they apparently do sell. I am just gonna try a different MBC...
